Moisture Content
Forum topic by Rob67 posted 04-28-2010 08:09 PM 1390 views 0 times favorited 7 replies Add to Favorites Watch
View Rob67's profile
Rob67
25 posts in 2899 days
04-28-2010 08:09 PM
As I am still new to woodworking and just got a moisture meter I was wondering what moisture content needs to be before I can work with wood. I had a recent problem with some small panels that warped real bad and I think it was because the wood wasn’t dry enough (or maybe I clamped it to tight or maybe I just am not doing it right).
7 replies so far
View David "Lucky Dawg" Brown's profile
440 posts in 2896 days
#1 posted 04-28-2010 08:23 PM
I’m right there with you on this subject!
-- dumpster diver delux
View richgreer's profile
richgreer
4541 posts in 2979 days
#2 posted 04-28-2010 10:41 PM
If you bought lumber from a lumber yard, mill or big box it should be dry enough when you get it. The need for a moisture meter arises when you cut down your own tree or somehow acquire some green lumber.
View NBeener's profile
NBeener
4816 posts in 3078 days
#3 posted 04-28-2010 10:45 PM
Got a few minutes?
I think this is a really good introduction to what we need to know about moisture content:
http://www.fpl.fs.fed.us/documnts/fplrn/fplrn226.pdf
-- -- Neil
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3190 days
#4 posted 04-28-2010 11:12 PM
Rich, Unfortunately you can’t trust the mills the lumber yards are buying from to dry to the correct moisture content. If lumber is in short supply, they will rush the drying. Lumber mills are just like any other business, some will try to get buy with something to make a buck. I buy from several very reputable dealers and still check moisture content frequently. I buy thousands of board ft of lumber every month and can’t afford to take a hit on my product coming back to me. It has happened in the past because I depended on suppliers to watch that sort of thing.
Moisture meters are cheap compared to eating a hundred or so cabinet doors.
Now Rob, in answer to your question, NBneer gave a good link that answers that well.
-- http://shepherdtoolandsupply.com/
View RexMcKinnon's profile
RexMcKinnon
2593 posts in 3099 days
#5 posted 04-28-2010 11:38 PM
Good link NBeener but I would like to add. Even if when get home and your wood is already in a good moisture range don’t start working right away. You should leave your wood acclimate to your surrondings for a few days.
-- If all you have is a hammer, everything looks like a nail!
View bigike's profile
bigike
4053 posts in 3192 days
#6 posted 04-28-2010 11:39 PM
between 6-8 percent is what i hear.
View Eagle1's profile
Eagle1
2066 posts in 2969 days
#7 posted 04-29-2010 11:52 AM
I heard 6-8 percent also. I usually let it aculmate to my shop for about a week, depending the weather outside.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
