Alternative to Plastic Resin Glue?
Forum topic by Michael James posted 04-28-2010 07:01 PM 5664 views 0 times favorited 11 replies Add to Favorites Watch
View Michael James's profile
Michael James
89 posts in 3287 days
04-28-2010 07:01 PM
Topic tags/keywords: question shaping glue
Hi there,
I’ve going back and forth on doing bent laminations or straight arms for a morris chair I’m going to build. I’ve done some digging on this awesome site and am thinking I might just be able to resaw some cherry on my tablesaw with the help of a handsaw.
Anyway, I can’t seem to find plastic resin glue in Canada and have heard that we just can’t get it due to the chemical components. That being said, what should I use otherwise?
I’ve read epoxy would be the next alternative but it’s super expensive and when you’re laminating so many pieices, it might get so expensive that it would be prohibititive.
I’ve heard Titebond III might work and I’ve also hear Gorilla Glue might work. Any thoughts out there from experience?
-- Michael James - www.michaeljames.ca
11 replies so far
Michael James
#1 posted 04-28-2010 09:55 PM
Thanks for the links. The tough part is that I believe the Urea Formaldhyde glue is also not available in Canada.
In response to your comment about Google – of course that was my first choice and I have poked around online for days researching this subject. Because most of the reliable content is from the US, they often reference products that are not available here.
Because of this, I am looking for opinions from people who have used such things. Is that not the point of a forum? Sharing discussions and experiences?
I’m starting to lose faith in this site…
View TJK's profile
TJK
14 posts in 3258 days
#2 posted 04-28-2010 10:46 PM
I haven’t done a ton of bent laminations but have used titebond II and never had a problem. Good luck.
-- Tim - He who knows best knows how little he knows.
View bigike's profile
bigike
4055 posts in 3527 days
#3 posted 04-28-2010 10:49 PM
have you tried amazon.com or jamestown distributers also highland woodworks has this glue too, i got some from amazon ofcourse i live in the US haven’t used it yet but plan to on a veneer project. i just find it funny these companies don’t deliver to you. the only other thing i can think of for bent laminations is contact cement the stuff used for laminating formica or plastic laminate to counter tops.
View Michael Murphy's profile
Michael Murphy
453 posts in 3244 days
#4 posted 04-28-2010 11:56 PM
I just called DAP’s tech support line and asked “Gigi” about it. She said that material is actually a discontinued product. That is why they don’t have it in their Canadian Catalog. She said there were no restrictions as far as she knew with regard to shipping it over the border.
She suggested ordering it from somewhere down here and shipping it.
Makes me want to go buy a 5 lb pail just to have around if they aren’t making it anymore.
She also said they don’t have a similar replacement product either.
They say PVA glues are too flexible for bent laminations. I am sure it would work if the laminations are thin to reduce the springback pressure.
Contact cement would not be a good choice.
-- Michael Murphy, Woodland, CA.
Michael James
#5 posted 04-29-2010 01:58 AM
Michael – thanks! What service.
I might look into that. I assume you’re speaking of Weldwood?
Any idea if poly glues are good? I’ve seen it done, but I’m assuming they spring a bit too.
View Ger21's profile
Ger21
1075 posts in 3370 days
#6 posted 04-29-2010 02:48 AM
You can get good quality, inexpensive Epoxy from US Composites.
http://www.shopmaninc.com/index.html
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
Michael Murphy
#7 posted 04-29-2010 03:03 AM
I was curious about it so I looked it up and called them. I didn’t think Urea-Formaldehyde glue would be banned, it’s the main glue manufacturers use for gluing up plywood. I think they still have a few plywood plants in Canada. They may be trying for lower formaldehyde emissions or something. Making it more difficult to deal with in small amounts like DAP “Weldwood” does.
When they outlaw glue, only Outlaws will have glue.
Try ordering it through amazon or look up Ace Hardware. There is a distributor in New York that’s pretty big in mail order for stuff like that. I don’t think there is a problem with crossing the border.
Ger21
#8 posted 04-29-2010 03:06 AM
Rob, what kind of problems did you have with it? I’ve been using it for a year now, and have been very happy with it. It’s 1/4 the price of West Systems.
Michael James
#9 posted 04-29-2010 04:22 PM
I’ll have a look to see if I can get some in for the US. With my luck, I won’t buy enough!!!
Thanks.
View tbone's profile
tbone
276 posts in 3923 days
#10 posted 04-29-2010 07:21 PM
Titebond III is a great glue. However, it dries dark brown. You might end up with a dark glue line.
I’m still a believer in the plastic resin glue—however, it’s shelf life is relatively short—about 1 year.
It will leave a dark glue line too.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
View bobkberg's profile
bobkberg
439 posts in 3312 days
#11 posted 04-29-2010 09:21 PM
Michael, I’ve done built-up laminations with Titebond II with good success. The key thing is keeping the laminations securely pressed together to avoid gaps and such. The leading top edge of my bedside tables is done that way.
Complete aside – I’d pick a better way of doing it than I did the first time though.
Good luck,
-- Bob www.singularengineering.com - A sideline, not how I earn a living
