Acceptable runout for a used 64A
Forum topic by DouglasFir posted 04-28-2010 03:12 AM 983 views 0 times favorited 2 replies Add to Favorites Watch
View DouglasFir's profile
DouglasFir
3 posts in 2922 days
04-28-2010 03:12 AM
Hi all,
I’ll be looking at a used PM 64A w/50” Biesemeyer fence for $450 tomorrow. It’s the type of saw I have a lot of experience using but not owning. I’ve never purchased a table saw before and I was wondering if there’s maximum level of acceptable arbor or shaft run-out with these saws (or any in general)?
I’m thinking it’s a pretty good deal but want to know if I’m getting myself into a project.
Thanks!
2 replies so far
View barryvabeach's profile
barryvabeach
159 posts in 3013 days
#1 posted 04-28-2010 03:26 AM
IIRC arbor runout should be quite low, .001 comes to mind, though I would think .002 or even .003 wouldn’t be a deal breaker. I would be more worried about whether the bearings sound good, and does the machine or the fence show signs of abuse. BTW. if you measure runout at the blade – any problems with the blade can effect the readings, and even if you have some poor readings, it is often pretty easy to tune even a bench top unit it to within .004 so long as nothing is bent.
View PurpLev's profile
PurpLev
8534 posts in 3617 days
#2 posted 04-28-2010 03:38 AM
for any saw, I would accept anything below 0.005”. however things can be tuned, and sometimes older saws (also depending on previous owners) are simply out of tune.
