Is this normal for a miter saw?
Forum topic by Hard_as_Wood posted 06-24-2016 09:54 PM 842 views 0 times favorited 8 replies Add to Favorites Watch
View Hard_as_Wood's profile
Hard_as_Wood
28 posts in 848 days
06-24-2016 09:54 PM
I got my Bosch GCM12SD gliding miter saw and my table doesn’t seem straight/flat.
Is there anything I can do about this? And won’t this throw my end cut off from 90 degrees?
see here: https://youtu.be/Doeo9ArCULY
-- Ciao!
8 replies so far
View mpounders's profile
mpounders
868 posts in 2801 days
#1 posted 06-24-2016 10:04 PM
In your video, it almost looks like the red zero-clearance spot is too low? Try it with the straight edge all the way across both side tables and see. The red part could easily be shimmed up, I would think. You might lose a little cutting depth, but you could span both tables with a piece of plywood or something?
-- Mike P., Arkansas, http://mikepounders.weebly.com
View kiefer's profile
kiefer
5618 posts in 2573 days
#2 posted 06-24-2016 10:11 PM
Take it back to where you bought it and get another one this one seems to have taken a tumble or was not perfect from the factory and slipped past QC .
Klaus
-- Kiefer https://www.youtube.com/user/woodkiefer1/videos
Hard_as_Wood
#3 posted 06-24-2016 11:07 PM
I did do that – take the steel across the whole bed and it did NOT ROCK, it was solid.
so… what does that mean? To me the high spot is where the no hand sign is, so the other one on the other side would just even things out.
I bought it from Amazon and I have a service center close by here. I might take it in tomorrow. See if they can do anything.
-- Ciao!
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2215 days
#4 posted 06-25-2016 02:48 AM
How does it cut?
View Woodchuck2010's profile
Woodchuck2010
704 posts in 764 days
#5 posted 06-25-2016 03:56 AM
Don’t settle for anything less than another new saw. I have the same saw and it was great out of the box. There is a warranty on it too and a 30 day return policy from Bosch. Don’t try to fix it yourself.
-- Chuck, Michigan,
View toolie's profile
toolie
2106 posts in 2535 days
#6 posted 06-25-2016 10:59 AM
Don t settle for anything less than another new saw. I have the same saw and it was great out of the box. There is a warranty on it too and a 30 day return policy from Bosch. Don t try to fix it yourself.
- Woodchuck2010
+1
View distrbd's profile
distrbd
2252 posts in 2353 days
#7 posted 06-25-2016 12:37 PM
I don’t know what the problem is, it looks like the throat insert is lower than the table. if that’s the case,why would that cause a problem when cutting?
You don’t put pressure on that spot anyway, it is after all too close to the blade, if you need to know whether the table is flat or not ,you will (as mentioned) need to use a longer straight edge and check the whole table/both sides of the blade.
The main concern should be if the fence is 90°to the blade /table. if the miter saw cuts 90°, then it is good to go.
http://www.thisiscarpentry.com/2010/07/23/miter-saw-tune-up/
-- Ken from Ontario, Canada
AlaskaGuy
#8 posted 06-25-2016 06:52 PM
How does it cut? Makes some cuts and check for square etc.
