Low Speed Sanding?
Forum topic by DonBoston posted 06-24-2016 03:20 PM 1060 views 0 times favorited 22 replies Add to Favorites Watch
View DonBoston's profile
DonBoston
81 posts in 1582 days
06-24-2016 03:20 PM
So, one of my more popular products, takes hours and hours to sand. It’s a wood/resin pendant, for either necklaces or earrings.
I normally sand them up to 220 on my belt sander, but after that, it’s all hand sanding up to 2000 with the last 3 steps being wet sanding.
Anything higher than 220 on the belt sander starts to melt the resin. So, I’m looking for a solution for power sanding, but at low speeds, which will allow me to cut hours out of these builds.
I’m currently contemplating using an air sander at a low speed, mounted to a small table top. Not sure how it will work though…
Any suggestions?
-- Don Boston RECreations by Don http://recreationsbydon.com
22 replies so far
View Woodknack's profile
Woodknack
12338 posts in 2500 days
#1 posted 06-24-2016 04:59 PM
View HokieKen's profile
HokieKen
6174 posts in 1258 days
#2 posted 06-24-2016 05:05 PM
Depending on your belt sander, you may be able to replace the motor with a slower speed or, if it’s belt driven, change the pulley ratio.
-- Kenny, SW VA, Go Hokies!!!
DonBoston
#3 posted 06-24-2016 06:17 PM
Buffer
- Rick M.
Have one in mind, every one that I have seen has been high speed.
View mpounders's profile
mpounders
890 posts in 3015 days
#4 posted 06-24-2016 06:39 PM
You might consider a rotary shaft grinder, that uses a foot pedal to control the speed. You can run them from 0-10,000 rpms. You can use different Dremel attachments or sanding drums as long as the shaft is not 1/4”. You would have to buy a Foredom handpiece to use bits with 1/4” shafts. Here is a link to a cheap one from Harbor Freight. It’s a little noisy, but it works well. Seems like it would be ideal for something small like a pendant.
-- Mike P., Arkansas, http://mikepounders.weebly.com
DonBoston
#5 posted 06-24-2016 06:53 PM
You might consider a rotary shaft grinder, that uses a foot pedal to control the speed. You can run them from 0-10,000 rpms. You can use different Dremel attachments or sanding drums as long as the shaft is not 1/4”. You would have to buy a Foredom handpiece to use bits with 1/4” shafts. Here is a link to a cheap one from Harbor Freight. It s a little noisy, but it works well. Seems like it would be ideal for something small like a pendant.
- mpounders
I’d be wanting to run a 5” hook and latch paper on it, would need something a little sturdier than that. Nice idea though.
View Richard's profile
Richard
1920 posts in 2810 days
#6 posted 06-24-2016 07:22 PM
There are a lot of Random Orbit Sanders that have variable speed that might work.
View rick1955's profile
rick1955
264 posts in 1551 days
#7 posted 06-25-2016 02:02 PM
I’d be doing tumbling or better yet vibratory finishing.
-- Working smarter with less tools is a true crafts person...
DonBoston
#8 posted 06-25-2016 05:12 PM
- Richard
I haven’t found one yet which will go a few hundred RPM’s, in a 5”.
DonBoston
#9 posted 06-25-2016 05:13 PM
I d be doing tumbling or better yet vibratory finishing.
- rick1955
I thought about that (vib), but not sure how that would do since it’s really wet work. At least it was back when I did stone work.
rick1955
#10 posted 06-25-2016 05:28 PM
There’s dry vibratory sanding as well. Based on your description it sounds like the way to go.
View hairy's profile
hairy
2750 posts in 3652 days
#11 posted 06-25-2016 05:54 PM
Variable speed lathe , drill press. Take the motor from a treadmill and make an attachment.
Look on CL for a cheap Shopsmith.
-- My reality check bounced...
View teejk02's profile
teejk02
484 posts in 1245 days
#12 posted 06-25-2016 07:28 PM
I agree with the buffing thing…jewelry outfits will have the attachments and the appropriate grits…pendant/earrings would suggest that the pieces are not that big in which case a Dremel type tool should work or if you make a lot of them a flex-shaft carving tool should work. For my rock tumbling/polishing stuff I use Kingsley North…they have a jewelry catalog.
View dalepage's profile
dalepage
360 posts in 960 days
#13 posted 06-25-2016 08:46 PM
Is it possible you could increase the ratio of the wood to the resin so that you could avoid the melting?
-- Dale
View diverlloyd's profile
diverlloyd
3022 posts in 1977 days
#14 posted 06-25-2016 08:49 PM
Dimmer switch
teejk02
#15 posted 06-25-2016 10:33 PM
- dalepage
or a harder resin?
