small sanding wheel for grinder
Forum topic by treesner posted 06-23-2016 11:20 PM 787 views 0 times favorited 2 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 1170 days
06-23-2016 11:20 PM
i’m doing some power carving and find that the discs are to large for tight contours and i hit the back of the disc on the piece.
is there any small solutions to: kutzall and or sanding flap wheels?
if i go smaller do i need to go to a drill instead?
2 replies so far
View Redoak49's profile
Redoak49
3672 posts in 2194 days
#1 posted 06-24-2016 10:58 AM
You might take a look at the Guinevere sanding system. Or if going really small look at small drums on a Dremel tool.
View mpounders's profile
mpounders
903 posts in 3101 days
#2 posted 06-24-2016 06:53 PM
I’m guessing since you mentioned discs that you may be using an angle grinder? You might look at a rotary shaft grinder.
-- Mike P., Arkansas, http://mikepounders.weebly.com
