Starter Pin Placement?
Forum topic by juniorjock posted 04-27-2010 12:43 AM 1020 views 1 time favorited 4 replies Add to Favorites Watch
View juniorjock's profile
juniorjock
1930 posts in 3886 days
04-27-2010 12:43 AM
Topic tags/keywords: router table starter pin
I’m finally getting around to adding a starter pin to my router table. I’m not exactly sure where to drill the hole for the pin. Or, should I go ahead and drill more than one hole so that if the situation came up, I’d have it ready to go. Any suggestions?
View syenefarmer's profile
syenefarmer
503 posts in 3201 days
#1 posted 04-27-2010 12:52 AM
Because it’s used when you don’t use a fence you can pretty much put it where you want to. I would think that the most versatile position would be somewhere on the right side of the bit as you face the table.
juniorjock
#2 posted 04-27-2010 12:55 AM
Thanks, but I kinda figured that. I was asking how far the pin should be from where the bit would be?
syenefarmer
#3 posted 04-27-2010 12:57 AM
juniorjock
#4 posted 04-27-2010 01:02 AM
That is perfect sf. Exactly what I was looking for. Thanks!
