Simple and effective drill press depth stop
Forum topic by ste6168 posted 06-22-2016 03:09 PM 963 views 0 times favorited 7 replies Add to Favorites Watch
View ste6168's profile
ste6168
252 posts in 1076 days
06-22-2016 03:09 PM
Topic tags/keywords: depth stop drill press grizzly
If you are anything like me, and own a drill press which uses the “two nut” method for adjusting the depth stop, then I have no doubt in my mind you are fed up with trying to set and adjust the thing. When depth is important, it becomes very frustrating, very quickly. I looked for a better solution to purchase, but couldn’t find much. Decided to do some searching, thinking, and make something. Disclaimer, this is not my original idea, I saw similar online at some point, so this is simply my variation of it.
This is a prototype that I made with scrap wood and parts I had already on hand. I plan to make a more refined version, with a harder wood (probably Hickory) and a shorter eye bolt, or possibly even a star knob if I am feeling crazy ;)
Much better so far, hopefully it helps one of you out there.
https://youtu.be/U3Yq6wkcGiQ *edit – not sure how to embed videos, or if its even possible…
7 replies so far
View GR8HUNTER's profile
GR8HUNTER
3279 posts in 617 days
#1 posted 06-22-2016 03:55 PM
smart
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
View Charles Holland's profile
Charles Holland
78 posts in 600 days
#2 posted 07-04-2016 07:08 AM
i follow you on Instagram. clever idea!
View splintergroup's profile
splintergroup
1873 posts in 1127 days
#3 posted 07-04-2016 02:00 PM
I’m with you 100% on the pain with those thumb nuts on the quill travel!
Excellent and effective solution.
View MrRon's profile (online now)
MrRon
4629 posts in 3148 days
#4 posted 07-05-2016 05:58 PM
Please explain how it works. Are you referring to the two jam nut type of depth stop used on older Delta drill presses?
View bandit571's profile
bandit571
19186 posts in 2587 days
#5 posted 07-05-2016 06:00 PM
I just use a strip of masking tape. set to the depth on the drill bit, leave a little extra tape to stick out like a flag. When the flag start sweeping the drill dust out of the way, you should be at the depth you want.
ste6168
#6 posted 07-05-2016 07:16 PM
- bandit571
This is what I do if I am drilling with a hand drill, or the stop doesn’t have to be extremely precise. However, I make one product where I leave about 1/32” of material using a forstner bit with a ground off point, in which I inset a magnet into the hole. Drilling the hole is one of the last steps, and I would hate to go a hair too far. Alternatively, if I backed off a bit, I lose a significant amount of pulling strength from the magnet, due to it pulling through the wood.
ste6168
#7 posted 07-05-2016 07:17 PM
- MrRon
The attached video explains it better than words. I do not have a Delta press, so I can not speak about them exactly, but I believe that yes, the two jam nut system is similar to what my Grizzly uses.
