Any pretreatment for a bartop before epoxy?
Forum topic by bhacksaw posted 06-22-2016 03:01 PM 667 views 0 times favorited 4 replies Add to Favorites Watch
View bhacksaw's profile
bhacksaw
163 posts in 2063 days
06-22-2016 03:01 PM
I have two black walnut slabs i’ve butt-jointed. planed, sanded and scraped. I wiped the dust off. Is there anything i can do to ensure the best looking color and grain (there’s a few curly maple butterfly keys) before putting down the mirror coat epoxy?
View pontic's profile
pontic
663 posts in 847 days
#1 posted 09-30-2016 06:24 PM
What you see is what you get with epoxy coats. Do a test piece first. Remember to have a heat gun handy when you apply it to chase out the bubbles.
-- Illigitimii non carburundum sum
View JayT's profile
JayT
6008 posts in 2450 days
#2 posted 09-30-2016 07:23 PM
If it was me, I’d hit it with some kind of finish first to darken the walnut, the epoxy may not do that. Danish oil or Tung oil would do a good job with color for the walnut, but will take a while to dry. De-waxed shellac, either from flakes or something like Zinsser Sealcoat, might be a good choice, too.
-- In theory, there is no difference between theory and practice. In practice, there is.
View Andre's profile
Andre
2367 posts in 2045 days
#3 posted 09-30-2016 08:44 PM
Make sure that it is REAL DRY! and warm! Any moisture and it could go cloudy happened on my Bar top using West Epoxy.
View Kelly's profile
Kelly
2187 posts in 3183 days
#4 posted 09-30-2016 09:08 PM
I used to buy my fifty-fifty mix in two five gallon cans at a time. Said another way, I’ve poured quite a bit of epoxy.
Early on, I learned to seal the surface before I poured. Otherwise, heating the pour would remove the bubbles, but would also draw more air out of the wood.
When I was doing plaques with photos or clippings, I used white glue to adhere the item to the wood, then brushed a coat or two over the clipping or photo. For news clippings, this stopped the print on the other side from bleeding through, like always did if I used oil based poly or just poured over them.
For burls and such, I just thinned poly and slopped it on, generously. After it dried, I went for it.
Oddly, I’ve never really taken the time to do a side by test using hardening oil [to get the “pop” of the grain] then covering it with poly, then just putting the poly on without the oil. As such, I cannot say whether there is a notable difference. Of course, switching to waterborne poly would be a game changer. One not for the better, I suspect.
