Stubborn frog bolts update SUCCESS!!!
« back to Hand Tools forum
Forum topic by Marn64 posted 06-22-2016 02:43 PM 538 views 0 times favorited 1 reply Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 837 days
06-22-2016 02:43 PM
Topic tags/keywords: humor question plane
I FINALLY GOT THEM OUT AFTER A WEEK OF FIGHTING THEM!
so here’s what happened, it turns out that that last bolt was both corroded and bent. I think the best verb to describe how I got it out is that I killed it.
Finally, when I put the blade in citric acid this happened, is there something wrong with the temper or something?
-- Benjamin, Milwaukee
1 reply so far
View JayT's profile
JayT
5708 posts in 2262 days
#1 posted 06-22-2016 02:52 PM
Glad the bolt finally came out, even if it was in pieces.
On the iron, if you are talking about the line across, that is the point where the hardened tool steel for the cutting edge is welded to the milder steel that makes up the upper part of the iron. Totally normal to see that after you de-rust an iron in citric acid or Evaporust. Once you wire brush or sand it just a bit to polish up the metal, that line all but disappears.
