Drum Sander accident
Forum topic by CanKuhn posted 1124 days ago 6479 views 0 times favorited 33 replies Add to Favorites Watch
View CanKuhn's profile
CanKuhn
21 posts in 1189 days
1124 days ago
Pictures are a bit disturbing: http://www.woodworkforums.com/f67/incident-jet-drum-sander-gore-warning-116562
OUCH!
-- Wood is Good!
33 replies so far
View Michael Murphy's profile
Michael Murphy
448 posts in 1177 days
#1 posted 1124 days ago
Ouch! I guess you shouldn’t try to use it to file your nails.
-- Michael Murphy, Woodland, CA.
View richgreer's profile
richgreer
4474 posts in 1246 days
#2 posted 1124 days ago
You normally don’t think of a drum sander as being one of the dangerous tools in the shop. This proves you have to be careful around every machine.
I wish the victim would explain a little about how this happened so that we can learn from that.
3808 posts in 2193 days
#3 posted 1124 days ago
Nobody should be that stupid and operate powered machinery.
Before we know it the Goverments are going to try to legislate who can operate equipment and perhaps even who can own same.
All because stupid people do stupid things.
Don’t get me wrong accidents happen but, by and large, most equipment injuries are caused by stupid people doing stupid things.
View TheDane's profile
TheDane
2676 posts in 1835 days
#4 posted 1124 days ago
Pretty gruesome … but a good safety reminder. Thanks for posting!
Somebody asked him how he did it … here’s the text of his response:
How did I do it?
Its a recently new machine for me. I was practicing some sanding.
The machine has two motors and a seperate switch for each. One motor drives the drum and one drives the in-feed table (its now evident to me there are some safety issues with this set-up). I had turned off the in-feed table and this may have put in my mind that everything was off. I then for some unknown reason put my right hand under the drum head, then the next thing I knew my fingers were jamb up in the machine. I quickly reailsed the drum was still going and reached over to turn it off. Then I tried to pull my fingers out and they wouldn’t budge without pain. I thought about calling out to the Missus (but she wouldn’t of heard me) to get the fire brigade but they probably would have wanted to destroy the machine, and I wasn’t going to have that. So I un-did the allen key headed screw that holds the cover shut, thank christ I only had this finger tight. I flipped the cover open to see my fingures caught between the drum and a 15mm dia roller bar that sits about 6mm off the sanding drum. After a couple of goes at getting them back out I decided that I just have to gritt my teeth and go for it… to hell with the pain… and got them out.
Before I started sanding I changed the sandpaper from 80 grit to 40 grit.
The sanding drum spins anti clockwise so it just grabbed my fingers and pulled them in an up in a flash.
As I’m walking inside I’m wriggling the fingers and everthing seems okay. Gets inside says to the missus I need bandage. She comes with a bandade, she sees it and says you need the doctor. So around to the local we go. I says to the doc just needs to be pulled together and stitched. The doc says no no it needs more than that you’re off to the Royal Perth.
My stay and treatment at the Royal Perth was absoultly fantastic.
This one fingure typing sure buggers a person out.
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1287 days
#5 posted 1124 days ago
aaaauch
thank´s for the reminder
TheDane Thank´s for the explanation
Dennis
TopamaxSurvivor
13194 posts in 1848 days
#6 posted 1124 days ago
He is lucky he didn’t get pulled in more!!
View David "Lucky Dawg" Brown's profile
440 posts in 1164 days
#7 posted 1124 days ago
Hope the graft takes and have a speedy recovery!
-- dumpster diver delux
View Chase's profile
Chase
439 posts in 1198 days
#8 posted 1124 days ago
Wow that looks painful! hope you make a good recovery, and thank you to the lesson for us all.
-- Every neighborhood has an eccentric neighbor. I wondered for years "who was ours?" Then I realized it was me.
View Mary Anne's profile
Mary Anne
1056 posts in 1380 days
#9 posted 1124 days ago
I hate to pick on the guy, and I hope he heals fast and well, however…
I hope to never utter the words that I put my hand anywhere “for some unknown reason.” Especially in the shop. The #1 safety rule in my shop is to ALWAYS PAY ATTENTION to what I am doing where my body parts are. If I feel my attention drifting even a little bit, it’s time to get the hell out there for a breather.
I have this same model sander, and one of the first safety decisions I made was to make it a habit to turn off the drum first, then the feed belt; turn on feed before turning on drum to give myself one more small layer of protection. If I get stupid and turn off only one thing, it will be the drum. The drum motor is very quiet and if you have any noise in your shop, you will not hear it. I have trouble hearing it with no ambient shop noise. Even so, I can’t imagine sticking my hand in there without making sure it is turned off and unplugged.
View msdameng's profile
msdameng
6 posts in 1126 days
#10 posted 1124 days ago
Never even thought about getting hurt with a sander before now!
-- Dusty, Mississippi
View Dez's profile
Dez
1097 posts in 2249 days
#11 posted 1124 days ago
Bet you didn’t think your fingers were that sticky! (Stuck to the wood and got sucked in and sanded)!
Ouch! Please be more careful, I can’t take too much gory stuff without loosing my lunch!
-- Folly ever comes cloaked in opportunity!
View SCOTSMAN's profile
SCOTSMAN
4312 posts in 1757 days
#12 posted 1124 days ago
The tissue on your hands face arms etc is softer than wood.If you have a machine which can chew up wood don’t you think it will make an even more unsightly mess of the tissue skin e muscle etc of your body.It’s not rocket science.I undrstand that this was an accident but we all need to realise more often ME INCLUDED that we take chances with wood machines at our peril..In the meantime I hope you get better soon and remember this should be a sound lesson to all of us.Alistair
View SnowyRiver's profile
SnowyRiver
45924 posts in 1652 days
#13 posted 1123 days ago
That doesnt look good at all.
-- Wayne - Plymouth MN
SCOTSMAN
#14 posted 1123 days ago
Don’t try this at a nudist workshop.LOLAlistair
View KnifeL's profile
KnifeL
86 posts in 1124 days
#15 posted 1123 days ago
Ow.
-- Will in Boulder, CO
showing 1 through 15 of 33 replies
