Jointer not leaving smooth surface
Forum topic by Mrowell posted 06-21-2016 11:21 PM 1245 views 0 times favorited 18 replies Add to Favorites Watch
View Mrowell's profile
Mrowell
200 posts in 1286 days
06-21-2016 11:21 PM
Topic tags/keywords: jointer problem wood tools surface question poplar milling help
I just got my new Grizzly 8” parallelogram jointer set up. Set up seemed pretty strait forward. After running a couple poplar boards through to test it out I found it is not leaving a very smooth surface? I have what almost looks like chip tear out but slightly different and across the whole board, not just the ends? I am new to a jointer so any help would be greatly appreciated!
-- Matt R
18 replies so far
View bbasiaga's profile
bbasiaga
1240 posts in 2142 days
#1 posted 06-21-2016 11:24 PM
Got pics?
With little to go on, I’d ask if you ran the board through with the grain in the right direction.
View MadMark's profile
MadMark
979 posts in 1600 days
#2 posted 06-21-2016 11:31 PM
Rotate the stock 180° and try again. Knots have wild grain and some chipout is normal. Lack of suction from the DC can cause chips to clog and get recycled into the cutters.
When in doubt, hit it with the bigger hammer!
M
View Trollin4Tuna's profile
Trollin4Tuna
7 posts in 1079 days
#3 posted 06-22-2016 12:46 AM
Is it the G0490w? I had one that left a terrible finish in addition to the fence being out of square by 3/4”. Also the rabbit table was cracked.
After a couple weeks back and forth with the technical department they had me send it back. They gave me a curtesy refund since it was out of the 30 day return period even though that was their fault.
All this being said, I’m going to get another one and hope for the best. Their customer service is great but with a machine that big it’s still a hassle. The actual jointer was almost dead coplaner out of the box. Too bad the fence was awful.
Mrowell
#4 posted 06-22-2016 01:49 AM
First off thanks for the responses! I did try flipping the board 180 to check if grain direction was wrong and I got the same results.
I’ll double check dust collection because I didn’t even think about that.
Yes it’s the g0490w, and after reading your comment I went and took a look and my fence is also out of square so I will be contacting them.
-- Matt R
runswithscissors
2843 posts in 2172 days
#5 posted 06-22-2016 02:34 AM
Is the fence out of square vertically, or unsquare from front to rear? The former is important, the latter not so much.
View JBrow's profile
JBrow
1366 posts in 1067 days
#6 posted 06-22-2016 02:37 AM
Mrowell,
Lighter cuts could help a little. I like a 1/32” deep cut, or even lighter. Takes longer to flatten or straighten a board, but lighter cuts seem to produce a smoother surface for me.
View pintodeluxe's profile
pintodeluxe
5757 posts in 2960 days
#7 posted 06-22-2016 04:18 AM
If the board looks rippled across the full width, your knives are set incorrectly.
Mrowell
#8 posted 06-22-2016 10:49 AM
-- Matt R
View rwe2156's profile
rwe2156
3092 posts in 1627 days
#9 posted 06-22-2016 12:04 PM
I wouldn’t be so quick to blame the machine because it looks to me like reversing grain to me. The other part of the board in the pic looks smooth. Reversing or swirling grain is often associated with knots.
The only way to avoid tear out in these cases is light passes/freshly sharpened blades or a spiral cutting head.
I would check the blades for sharpness and make sure there is no remnant of the goo they put on everything.
Then try another board. I’m sure it will be alright.
View Aj2's profile
Aj2
1725 posts in 1945 days
#10 posted 06-22-2016 01:01 PM
Just looks like dull knives.The wood looks like popler,You could try honing the knives still in the machine.
Check for a high one first.
-- Aj
Mrowell
#11 posted 06-22-2016 02:10 PM
Do you typically have to hone new jointer blades? I was doing pretty light passes but Ill do even less and see if that helps!! Ill also double check the blades and make sure they are clean!
I wouldn’t think the knives are dull since they are brand new but I guess you never know!
-- Matt R
pintodeluxe
#12 posted 06-22-2016 04:48 PM
Now that I see the picture, that’s just gool ol’ tearout. Straight knives are notorious for causing tearout. Sure you can try reversing the grain direction, but often the grain direction changes across the length of the board. I have experienced tearout with brand new straight knives on my jointer. It is just something you will experience from time to time.
Try cleaning it up with the planer. Take light cuts, and angle the board slightly. As a last resort you can wet the wood slightly with a spray bottle. Wet wood fibers are less likely to tearout.
Ultimately, tearout is what made me install a helical head on my planer. A helical head with carbide teeth has a shearing action and nearly eliminates tearout. They are costly, but hey, so is the lumber I ruined with straight knives.
Mrowell
#13 posted 06-22-2016 06:23 PM
Ok thank you! I will try to do shallow passes and plane/sand out anything else! I was going to order a jointer with a helical head but it was on back order for several months and I needed a jointer. I plan to upgrade once these knives get dull or I have a little spare cash.
Thank you all for the input!
-- Matt R
rwe2156
#14 posted 06-22-2016 06:40 PM
Yup.
Mrowell
#15 posted 06-22-2016 06:47 PM
I just wish I had a 20” planer lol I have a little 12”
-- Matt R
