Leopard Wood and Tung oil?
Forum topic by douginaz posted 12-16-2007 06:25 PM 5058 views 2 times favorited 3 replies Add to Favorites Watch
View douginaz's profile
douginaz
220 posts in 3967 days
12-16-2007 06:25 PM
Topic tags/keywords: question leapord wood box
Merry Christmas all. I’m in the middle of making a rather large 16X21X10” box for my nephew. I pretty much have the mechanics of it made so the mind goes to finishing. My standard in the past has been bullseye shellac and wipe on poly. I normally don’t use a stain. The wood is new to me, leopard wood has always held a little mystery to me. I just love the look but don’t have a clue what to use for a finish on it. I’m thinking just plain tung oil until I get the pop and smoothness I’m looking for. Any and all suggestions are welcome.
Thanks All,
Doug in AZ.
-- If you need craft books - please visit our small business at http://www.wittywife.com
3 replies so far
View Dan'um Style's profile
Dan'um Style
14171 posts in 3948 days
#1 posted 12-16-2007 06:34 PM
If it were me, I’d use oil finish, and follow with shellac. Should make it pop !
View schwingding's profile
schwingding
133 posts in 3790 days
#2 posted 12-17-2007 05:31 PM
Yup, oil of choice, then shellac. My favorite finish is oil, shellac, then ArmRSeal. I prefer Watco as it is thinner than most “tung oils” I’ve used and soaks in further.
Couple of coats of oil, then one coat of shellac, then sand to 320 to get rid of the fuzzies. Then 3 coats of ArmRSeal, the 2nd one rubbed in with 0000 steel wool. Then when cured rub out with Liberon 0000 wool and Howard FeedNWax. Take a look at the shaker desk in my projects library, it was finished exactly that way.
Leopardwood will respond wonderfully to the oil. If you could wipe it down with a light brown dye first, then sand it with 320, you’ll pop the figure even more.
-- Just another woodworker
View mroe's profile
mroe
7 posts in 2197 days
#3 posted 01-02-2017 01:25 AM
Schwingding, your above comment suggesting “wipe it down with a light brown dye first, then sand with 320”. When does the dye go on; before the oil or after the oil? Thanks
mroe6
