How big to build a V drum sander
Forum topic by swayze posted 04-26-2010 04:53 AM 2627 views 0 times favorited 2 replies Add to Favorites Watch
View swayze's profile
swayze
97 posts in 3208 days
04-26-2010 04:53 AM
Topic tags/keywords: sander
Well I finally got the bearings and shaft to start building a v drum sander. The shaft comes in 36” lengths so I could build the drum up to about 30” long if I wanted to – but do I want to? How big would you build the drum if it was you? At 30” I could sand some pretty big panels but would this thing be to bulky, big, heavy or anything else I’m not thinking of? Also what type of glue should I use to glue down the velcro? I’m thinking I’ll build the drum out of Mdf and make it 4” diameter. I am still thinking that I make it a table top version (put it on a workmate when using it). I just finished building a armoire and I could have used this sander for just about every aspect of the build so I know it will get used a lot. So lets hear your thoughts on building this thing as I know some have already built these and a lot of others are wanting to. Thanks for the thoughts.
2 replies so far
View TheDane's profile
TheDane
5516 posts in 3783 days
#1 posted 04-26-2010 04:33 PM
My sander is an 18” (kit from Stockroom Supply) ... http://lumberjocks.com/projects/29085 .
I suppose bigger can always be better/nicer, but if I did gone to a 24” or 30”, I would have created some serious storage space problems.
The sander I built stows under a workbench along with my planer, scroll saw, and miter saw. If the sander were any longer, one or two of those other tools would have to go.
I sanded a pair of 24” wide panels on my 18” sander this past weekend … did about 13” one way. flipped the panel around and did about 13” the other way. I’m sure they are not perfectly flat, but I can’t find a crown or flaws in the center where I overlapped the passes.
swayze
#2 posted 04-26-2010 09:38 PM
Thanks for the reply Dane, I was wondering about sanding that way. I have the room now but a couple of more tool purchases and that may not be the case.
