Long countertop build questions
Forum topic by missesalot posted 06-21-2016 04:14 PM 872 views 0 times favorited 20 replies Add to Favorites Watch
View missesalot's profile
missesalot
102 posts in 1745 days
06-21-2016 04:14 PM
Hey all. I’m working on a 12’ long black walnut countertop for our kitchen. This will be plank style build, planning on using a built up edge for a thicker look. I’m using 4/4 stock, that is 8’ long or less. This countertop will have a sink installed in it. Since I don’t have 12+ long stock, i’m going to be gluing up boards end to end. So far I think I’ll be able to get all the end to end joints located where the sink cutout will be, with the exception of the front and rear most plank, as I figure i’ll need the strength of a solid piece in those areas. My question is, will using domino’s to make those end to end joints work, and do i even need to do that considering the large amount of edge grain that I’ll be gluing up. This is my first build on something not using full length stock so I’m sorta feeling my way through it. Thanks in advance, be gentle:-)
20 replies so far
View TheFridge's profile
TheFridge
10334 posts in 1632 days
#1 posted 06-21-2016 04:26 PM
Dominos would be be hell of a lot better than than gluing end grain to end grain. Which doesn’t have much strength at all.
Put solid piece in front and back.
If the only end grain to end grain butt joints are on the front and rear you could probably get by without a domino there but it definitely wouldn’t hurt.
missesalot
#2 posted 06-21-2016 06:07 PM
ok, dominos are easy, i’ll use a bunch.
the front and back pieces WILL have an end to end joint, but not near the sink hole, i’ll domino the hell out of those.
am i right in assuming that the long grain contact will be extremely strong, or is this a false sense of security?
View bruc101's profile
bruc101
1246 posts in 3688 days
#3 posted 06-21-2016 06:20 PM
I built a 22 foot long wood top quiet a few years ago and I used scarf joints. About two years ago the people built a new home. I designed their kitchen to incorporate the same countertop in it. When we finished installing her new kitchen and removed the top from her old home the top was just as strong as the day I built it.
The top was so long we made top cabinet supports like a set of face frames to fit in the inside of the cabinets to screw the top down to. On both sides of the sink we put supports as part of the support frame. The sink was a Kohler and had to weight at least a 100 pounds and the top handled it just fine.
-- Bruce Free Plans http://plans.sawmillvalley.org
missesalot
#4 posted 06-21-2016 06:22 PM
Bruc101, how thick was that top? This one will really only be 4/4 thick, maybe a little less finished, with the built up front edge, and one end. would a scarf joint be a good option on soemthing that thin?
bruc101
#5 posted 06-21-2016 06:29 PM
The top was 4/4 Cherry with a built up edge. When I built the top I offset the scarf joints. It was actually and still is a very pretty top. I used scarf joints on the drop edge too.
Scarf joints are centuries old and are still holding up old homes and buildings. I’ve got an 18 foot top to build a little later out of 8/4 yellow pine and I’ll use scarf joints on it also.
I would suggest you make a sample and see how it works for you.
View Woodknack's profile
Woodknack
12369 posts in 2526 days
#6 posted 06-21-2016 06:58 PM
I would shiplap or scarf. Scarf will look better but if you get any moisture you risk the edge of the scarf lifting. I would like to see it when done.
View AlaskaGuy's profile
AlaskaGuy
4509 posts in 2455 days
#7 posted 06-21-2016 07:02 PM
I could be wrong but all the commercial plank and butcher block counter tops look like simple butt joints. They are aesthetically pleasing and I’v never seen one fall apart.
I’d think the domino’s would help greatly with aliment.
missesalot
#8 posted 06-21-2016 07:10 PM
I’m going to play around with both later and see how it goes. What angle do you recommend cutting the scarfs? My gut is telling me that the dominos will work but I haven’t used scarfs on anything like this so I’m curious to try. Just cut with a miter/chop saw?
View jbay's profile (online now)
jbay
2678 posts in 1046 days
#9 posted 06-21-2016 07:12 PM
I would use a finger joint router bit on the ends.
missesalot
#10 posted 06-21-2016 07:12 PM
The other thing I’m nervous about is scribing the thing to the wall over the base cabinets. Old house, nothin is straight…at all. So I’m going to leave it a little big to give me a couple whacks at it. This is actually he long side of an L shaped top, other side is short so I’m not worried about that one.
View Lazyman's profile
Lazyman
2527 posts in 1534 days
#11 posted 06-21-2016 07:17 PM
The other thing I m nervous about is scribing the thing to the wall over the base cabinets. Old house, nothin is straight…at all. So I m going to leave it a little big to give me a couple whacks at it. This is actually he long side of an L shaped top, other side is short so I m not worried about that one.
- missesalot
Would a backsplash help to hide where the top meets the wall? You may still want to scribe and cut the line but it would at least hide any imperfections.
missesalot
#12 posted 06-21-2016 07:41 PM
Yeah you’re probably right, but then wouldn’t I need to scribe the backsplash to some extent?
Lazyman
#13 posted 06-21-2016 08:07 PM
I don’t think so but someone with more experience than I have might disagree? My logic is that as long as the backsplash appears parallel to the long joints in the top it won’t matter. You may have to caulk and paint around the top and ends of the backsplash to hide minor imperfections but If you have some huge divots or humps it might make more sense to level out the wall with some joint compound first. Of course if the problem is that the corner the counter is in is really far off from square, I am not sure how to deal with that.
runswithscissors
2843 posts in 2171 days
#14 posted 06-22-2016 03:09 AM
If you do scarf joints, do not try the miter saw. A scarf joint should have a minimum of 1:8 thickness to length ratio, even up to 1:12. They are a very strong joint, used often in wooden boat building.
But I would probably try JBay’s suggestion to use a finger joint router bit. They look okay when seen on edge, and seem to be strong enough.
View oldnovice's profile
oldnovice
7199 posts in 3514 days
#15 posted 06-22-2016 04:13 AM
When I built mine I used 1/4” plywood splines since bisquits and dominoes weren’t around yet and dowels don’t like me! Cut the mortises with my router and the 1/4” × 2” wide splines on my table saw.
