| Forum topic by USCJeff | posted 343 days ago | 453 views | 0 times favorited | 4 replies | ![]() |
343 days ago |
I’m a bit frustrated after wasting a coupole hours attempting to mount a shop made router wing for my tablesaw. Long story short, I used laminated MDF with a hardwood edges. I struggled to get it mounted flush. I ended up compromising the strength of the wing after screwing and rescrewing lag bolts into it. I drilled through the fence rails to attach the bolts. If anyone cares to share how they’ve done theirs, it would be much appreciated. Pictures would be awesome. Some thoughts I’ve had are using angle iron to frame the wing. I could add a 45 degree support to create a triangle to support the weight. There are also three mounting holes where the factory wing was installed. Perhaps I could incorporate those. Thanks all -- Jeff, South Carolina |
