Planner question
Forum topic by Walt M. posted 04-24-2010 04:37 PM 1196 views 0 times favorited 10 replies Add to Favorites Watch
View Walt M.'s profile
Walt M.
245 posts in 2885 days
04-24-2010 04:37 PM
I have a dewalt 734 planner and sometimes the board stops moving thru it and I have to push it thru . I’m only taking a 1/32 off or less, most boards are 2” to 6” wide so I know I’m not exceeding any limits here anymore than a 1/32 and the board won’t go thru at all. The planner is pretty new and I’ve checked the rollers for anything that might cause this. I set the in and outfeed tables slightly higher(on the outermost points) to reduce snipe and have used a little wax on the bed otherwise I haven’t done anything to it. Is this common or do others have this problem?
Thanks
10 replies so far
View bhack's profile
bhack
349 posts in 3595 days
#1 posted 04-24-2010 05:08 PM
I would clean the rollers with acetone or something similar. That seems to help on mine.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
View bigike's profile
bigike
4053 posts in 3164 days
#2 posted 04-24-2010 05:25 PM
me too on the acetone or minerl spirits
View dmoney's profile
dmoney
191 posts in 2954 days
#3 posted 04-24-2010 05:40 PM
my ryobi does this sometimes, i just give a push with my hand or with the next board
-- Derek, Iowa
View Aaron Taylor's profile
Aaron Taylor
37 posts in 3025 days
#4 posted 04-27-2010 12:08 AM
Walt,
I use a product by Bostik called Topcote. It coats the surface of your tools, table saw, planer bed, joiner bed, router table and makes them really, really slick. I was having the same problem with my 735 DeWalt planer and it fixed that problem right up. You do have to keep putting the stuff on every now and then, but it really does work, and I haven’t seen any side effects during my finishing from any that might have rubbed off. It runs for around $18 a can from woodworkers supply. I haven’t looked for it any place else, so I am not sure if it might be cheaper.
Hope this helps.
Aaron Taylor
Hebron LLC – Magdalena, New Mexico
-- "Insanity runs in my family. It practically gallops."--Cary Grant from the movie Arsenic and Old Lace
View juniorjock's profile
juniorjock
1930 posts in 3641 days
#5 posted 04-27-2010 12:46 AM
I usually clean the rollers off with a micro-fiber cloth. I do this pretty often and don’t wait until I have to. Keeps the lumber moving.
View Sawdust4Blood's profile
Sawdust4Blood
393 posts in 2897 days
#6 posted 04-27-2010 01:41 AM
is your planer connected to a dust collection system? Back up of chips/dust on the rollers due to inefficient extraction can cause them to lose grip. With my 734 this is almost always the cause of boards not getting pulled through. Correcting the dust collection problem and cleaning the rollers with mineral spirits has fixed the problem for me every time.
-- Greg, Severn MD
View 8iowa's profile
8iowa
1566 posts in 3636 days
#7 posted 04-27-2010 02:07 AM
Greg is right on! Before I got my dust collector I had to frequently clean out my planer and use mineral spirits to clean the outfeed roller. Now, when a board starts to need a push, I know that my blades are dull.
Walt M.
#8 posted 04-27-2010 02:23 AM
I did use it once or twice without the dust collection hooked up and yah what a mess. I’ll try the Topcoat Aaron thanks (I’ve actually been thru Magdalena when I was younger. Grew up in Albuquerque) and change the blades thanks everyone
View Mary Anne's profile
Mary Anne
1058 posts in 3084 days
#9 posted 04-27-2010 02:31 AM
Don’t know if this will help you with the Dewalt, but I recently just the same problem with my Grizzly. The fix was to take off the shroud and clear sawdust that accumulated inside, at the ends of the rollers under the springs. It was an easy fix.
View goggy's profile
goggy
73 posts in 3291 days
#10 posted 04-27-2010 03:57 AM
I have the identical problem Walt. I dont have a dust collection issue but I do have a can of topcoat (good stuff by the way). Let me know how you make out.
