frog bolts dead rusted in, need help *UPDATE No. 2*
« back to Hand Tools forum
Forum topic by Marn64 posted 06-19-2016 07:20 PM 1099 views 0 times favorited 29 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 691 days
06-19-2016 07:20 PM
Topic tags/keywords: question plane
Hey, so I got this stanley type 18 5C recently, and I’ve been dissassembling it, but the 2 little bolts for the frog are dead rusted in and partially balded, I have been getting pretty desperate and I have considered a blowtorch. Anyone got any alternatives or could offer me any other advice?
UPDATE
Hey, pb blaster worked pretty well, I got one of the frog bolts out, but the other one is still stuck, as is the brass depth adjuster. where should I go from here?
as for the bolt I did get out, its heavily corroded and not worth keeping, I’ll just de-rust it and archive it so I still technically have the complete plane.
UPDATE 2
I’m done with this thing, I’m just gonna get a screw extractor and remove it. The bolt is is so damaged that its not worth saving. I haven’t done a screw extraction before (on a plane at least) so can anyone give me some tips? I don’t want to accidentally punch through the sole or damage the frog. After this, my last battle is getting the depth adjuster wheel out, as it is stuck.
-- Benjamin, Milwaukee
29 replies so far
View kdc68's profile
kdc68
2638 posts in 2182 days
#1 posted 06-19-2016 07:28 PM
Try Kroil penetrating oil
-- Measure "at least" twice and cut once
View OSU55's profile
OSU55
1521 posts in 1895 days
#2 posted 06-19-2016 08:03 PM
PB Blaster is another brand. Let sit for several hours after application. A hammer type impact driver can work wonders for this (after the oil soak). If that won’t do it, then apply heat with a torch and try the impact driver again.
View Johnny7's profile (online now)
Johnny7
346 posts in 996 days
#3 posted 06-19-2016 08:10 PM
Don’t know what you mean by “balded”—do you mean the slots are f**ed up?
+1 to kdc68’s suggestion – Kroil has no equal
Marn64
#4 posted 06-19-2016 08:23 PM
Don t know what you mean by “balded”—do you mean the slots are f**ed up?
+1 to kdc68 s suggestion – Kroil has no equal
- Johnny7
Yes, that is what I meant, the slots are in bad shape. I couldn’t think of a better term other than that, but in hindsight, f’ked up would have worked even better.
Johnny7
#5 posted 06-19-2016 09:44 PM
with the slots in tough shape, it’s even more important to let the penetrating oil do its thing—don’t rush it.
one extracted you can use a needle file to restore the slots
Marn64
#6 posted 06-19-2016 10:04 PM
with the slots in tough shape, it s even more important to let the penetrating oil do its thing—don t rush it.
- Johnny7
cool, I’ll let it sit overnight and get an impact driver and a torch if needed tomorrow, do you know a good cheap impact driver?
View JoeinGa's profile
JoeinGa
7733 posts in 1912 days
#7 posted 06-19-2016 10:26 PM
I’ll second the motion for using PB Blaster. That stuff rocks !
View TheFridge's profile
TheFridge
8881 posts in 1391 days
#8 posted 06-19-2016 10:26 PM
PB blaster it and beat the bolt heads with screwdriver and torch it is one way. I’d try tapping the heads with a screw driver and hammer before using an impact.
Marn64
#9 posted 06-20-2016 12:14 AM
PB blaster it and beat the bolt heads with screwdriver and torch it is one way. I d try tapping the heads with a screw driver and hammer before using an impact.
- TheFridge
I’m assuming I’d use a propane torch, not acetylene?
View Don W's profile
Don W
18605 posts in 2473 days
#10 posted 06-20-2016 12:44 AM
Marn64
#11 posted 06-20-2016 12:47 AM
If you ve got a torch, use it!
http://www.timetestedtools.net/2016/01/27/saving-a-stanley-type-2-risk-equals-reward/
- Don W
Wow Don, as always stellar work on that type 2.
TheFridge
#12 posted 06-20-2016 01:01 AM
I use whatever’s at hand. I try to avoid heating the casting as much as possible.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1480 days
#13 posted 06-20-2016 04:00 AM
are you going to de-rust it? of so toss it in with the frog on and the de-ruster will work it’s way in and probably loosen them.
TheFridge
#14 posted 06-20-2016 04:25 AM
Definitely wouldn’t hurt if you are using Evaporust. Citric acid I would be cautious. I think it would need to be neutralized if it gets into the crevices.
Marn64
#15 posted 06-20-2016 05:55 PM
are you going to de-rust it? of so toss it in with the frog on and the de-ruster will work it s way in and probably loosen them.
- daddywoofdawg
I’ve been trying de rusting, no results :(
showing 1 through 15 of 29 replies
