Sharpening Table Saw blades
Forum topic by scottb posted 1090 days ago 5109 views 0 times favorited 13 replies Add to Favorites Watch
Rockler
View scottb's profile
scottb
3409 posts in 1298 days
1090 days ago
I’ve recently traded out the saw blade on my table saw, (The new blade was a perfect indicator of how dull the old one had become!) and my father has done the same. With the cost of a new blade being what it is (and knowing that they can be sharpened a few times) What have you all done? Started a used blade collection? Have any sharpening tips, or where do you outsource this?
Thanks,
28894 posts in 1371 days
1090 days ago
Scott:
I found a guy in NJ that sharpened with what he called his furniture grade sharpening with 600 grit diamond instead of 400 grit.
I get zero chipout on plywood as long as it is sharp.
Checking around in Delaware everyone wants to sharpen to 400 grit.
See if you can get 600, it could be that the new ones that you get from Forrest etc might be originally sharpened to 600.
But sharpening is the way to go. 15-20 bucks and you’ve got the equivalent of a new blade. Providing it was not a dollar-store blade to begin with.
I’ve taken some skill saw blades to him and he will say not worth sharpening or for another Ya! Sharpen it. So he can see the difference in quality of the original blade.
Unfortunately he is 200 miles from me now. So I might have to ship. But a 16” blade weight 20 lbs or so. (It seems like a ton)
I just picked up 2 16” blades from the woodworkers group that I’m a member of. They were given to the club by Seally mattress. One is brand new and the other has been sharpened. But they are both 60 tooth so good rip blades.
View Obi's profile
Obi
2189 posts in 1208 days
1090 days ago
I wanna see the saw that takes a 16” blade
-- http://ye-olde-cabinet-shoppe.com/
scottb
1090 days ago
One blade is the original that came with my Delta Saw, another is a Freud 60 (or perhaps 80) tooth… come to think of it, I inherited a few others with my shopsmith… so if I did have to mail them out, I’m sure I’d save on shipping, provided they all had some life left in them.
The only place I’ve come across thus far (was a Mail order service from DeWalt. Not sure if they’re limiting to only their blades, but the cost is in line with what you found Karson.
You just did a google search initially or did he live nearby at one time?
View thewoodwhisperer's profile
thewoodwhisperer
333 posts in 1155 days
1090 days ago
I ship all of my blades, including my jointer and planer blades, to Forrest in Jersey. I use a WWII so I like the idea of staying with the same company for sharpening. But I hear they do excellent work on other manufacturer’s blades as well. Highly recommend them.
marc
-- For free video tutorials and other cool woodworking stuff, check out http://www.TheWoodWhisperer.com
Dick, & Barb Cain
7209 posts in 1270 days
1089 days ago
Every so often I touch up my blades with my diamond hone, & they work like new again.
View Dollarbill's profile
Dollarbill
91 posts in 1109 days
1089 days ago
I agree with Marc and Dick. But many times when I thought my WWII was starting to get dull I found that it just needed a good solvent cleaning because of pitch build up.
Bill
-- Make Dust
1089 days ago
I stand corrected about the sharpening grit that my sharper used on his resharpening. When I talked to him today he said that normal sharpening is 180 grit and that his furniture grade sharpening is 400 grit.
dennis mitchell
3854 posts in 1285 days
1089 days ago
I keep a can of oven cleaner in my shop to clean my blades. Spray on wipe off.
View Bwillie's profile
Bwillie
103 posts in 1077 days
1069 days ago
I use Ridge Carbide. They apparently use a 1200 grit diamond wheel for sharpening. I have some of their blades and literally can joint an edge with’em. I cut a lot of miters with very dense woods w/o chipout. I also have one on my Compound miter saw.
These are really scary sharp, and they can sharpen bades for 13 bucks.
-- ICN, Bill, (http://www.beavercreekfitness.com)
View Dusty's profile
Dusty
785 posts in 1127 days
1069 days ago
I must be the exception and odd ball here.
I do clean the pitch off my blades and am very very careful not to hit nails etc. However, I feel very strong that its not a sharp blade that is the one that is dangerous. I firmly believe its the dull blade that can really cause all kind of safety issues not to mention all sorts of problems with the wood. To this day I haven’t had a saw blade sharpened nor will . I am careful , keep them clean and when they get dull I change them.
Period.
I then either donate them to a new woodworker, habitat for humanity, or sell them for little or nothing at a garage sale or just give them away.
I have did this since I started woodworking. I think it goes back to the days when I operated heavy equipment and fought “sharpened” cutting edges all day on my scraper. The wear and tear on my machine not to mention addition fuel consumption simply wasn’t worth it to me.
-- Dusty
View Bill's profile
Bill
2553 posts in 1132 days
1068 days ago
I would agree that the dull saw blades are more dangerous than the sharp ones. When the blade is dull, you have to apply more pressure to get the wood through, which can cause all kinds of problems. I did not notice this until my dad recently changed the blade on his saw. Wow, what a difference a sharp blade made. It was almost like a different animal. Now, things are a pleasure to cut, they flow smoothly, and much less tendency for binding, etc.
View Max's profile
Max
16786 posts in 1244 days
1068 days ago
I have never had any problems with re-sharpened table saw blades. All of the blades that I use are carbide tipped, as I believe most of all of everybody’s is. I take them to a local sharpening business that I use for my planer blades as well. They check all of the tips under a microscope and replace any that are nicked or cracked and sharpen and balance them. Have had great success with them…
Bwillie
1068 days ago
The new issue of WoodWorkers Journal has an article on blade sharpening. To my surprise the owner of Ridge Carbide who I use, was interviewd on the topic.
