square for glueing up boxes
« back to Joinery forum
Forum topic by treesner posted 06-19-2016 06:48 AM 1249 views 2 times favorited 12 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 993 days
06-19-2016 06:48 AM
what’s your guys favorite jig (bought or hand made) for squaring up boxes while glueing or screwing together? Been doing a lot of plywood boxes and looking at different techniques, whats yours?
Any difference between clamping the 90 on the outside or the inside or both sides?
12 replies so far
View MrUnix's profile
MrUnix
6769 posts in 2227 days
#1 posted 06-19-2016 06:59 AM
Made out of some scrap wood and a few screws. Work great and easy to use.
Thanks to Izzy Swan. Video on making and using them here:
How to make wood Corner Clamps!
View distrbd's profile
distrbd
2252 posts in 2475 days
#2 posted 06-19-2016 01:35 PM
Great video, thanks Izzy & Brad.will have to make a few . I looked for plastic one on Amazon,the problem is,you can’t buy just one,you need at least 4 .with the shop made type we can have as many as we want,different sizes too for smaller trinket boxes or similar projects. Great quick project.
-- Ken from Ontario, Canada
View AlaskaGuy's profile
AlaskaGuy
4217 posts in 2338 days
#3 posted 06-19-2016 08:25 PM
I just make sure my parts are cut square especially the back of the bottom of the box. I hardly ever use squaring blocks.
MrUnix
#4 posted 06-19-2016 08:38 PM
- AlaskaGuy
So you don’t use clamps when gluing?
View Loren's profile
10476 posts in 3676 days
#5 posted 06-19-2016 09:29 PM
A little exotic: I have a vacuum pump for veneering
and I made a right-angle fixture with vacuum seals
on both faces. Sometimes, when making a bookshelf
case or something like that I use it to hold parts
together while putting nails or screws in. An advantage
is one side can be sticking straight up so it helps
with quick assemblies when I don’t want to mess with
setting up an assembly table.
Pictures here: http://lumberjocks.com/Loren/blog/35682
AlaskaGuy
#6 posted 06-19-2016 09:58 PM
- AlaskaGuy
So you don t use clamps when gluing?
- MrUnix
I don’t use clamps for squaring purposes. Since most of my work is cabinet type work I use screw and applied ends don’t need clamps.
View tacky68's profile
tacky68
70 posts in 1456 days
#7 posted 06-19-2016 10:13 PM
I read in ww’ing magazine (not sure which one) in the reader tips section, that a 2 gang (four square) metal
electrical box works well for the inside corner to clamp to. The writer claimed the boxes were dead square. I have not yet had the opportunity to try this, so I can not verify. Seems like it would work though, and boxes are cheap, rigid, and durable.
Tim.
AlaskaGuy
#8 posted 06-19-2016 10:51 PM
These guys say it better that me.
http://www.woodweb.com/knowledge_base/Squaring_Up_Cabinets.html
View rwe2156's profile
rwe2156
2967 posts in 1509 days
#9 posted 06-20-2016 11:45 AM
Cabinets: I use Rockler jigs (one of them is NOT square, BTW) but really only to hole the pieces while I screw them together.
Drawers, boxes, carcases, etc: They usually have a bottom, right? Install during glue up and & check diagonals.
I’ve found if the parts are square & joints are tight, the assembly will be square, too.
View HokieKen's profile
HokieKen
5288 posts in 1167 days
#10 posted 06-20-2016 01:28 PM
I made a couple of these about a year ago but mine are 16” on a side. I use them on large stuff.
And I “accidentally” got a couple of these that are 6” on a side in a box I bought at an estate auction a while back. They come in handy for smaller stuff.
-- Kenny, SW VA, Go Hokies!!!
View ScottM's profile
ScottM
654 posts in 2175 days
#11 posted 06-20-2016 04:18 PM
- HokieKen
Same here. I also made a set of smaller ones. Pretty handy and used up some scrap 3/4” ply.
View ChefHDAN's profile
ChefHDAN
1067 posts in 2878 days
#12 posted 06-21-2016 02:32 AM
Yep Me too, they work great, I cut the hole larger for mine to be able to use my quick clamps
- HokieKen
- ScottM
