Dowels
Forum topic by Mrkixx posted 06-18-2016 02:09 AM 896 views 0 times favorited 9 replies Add to Favorites Watch
View Mrkixx's profile
Mrkixx
71 posts in 2182 days
06-18-2016 02:09 AM
Has anyone made a dowel jig and if so how did you do it
Thanks in advance.
9 replies so far
View sawdust703's profile
sawdust703
270 posts in 1622 days
#1 posted 06-18-2016 08:24 AM
I make mine on the lathe, or use a round over bit in the router. I can size the smaller ones better on the lathe, but for bigger dowels, its just as fast to run the wood over the router table using a round over bit.
-- Sawdust703
View Jim Finn's profile
Jim Finn
2687 posts in 3124 days
#2 posted 06-18-2016 02:52 PM
Yes what Sawdust703 said. If you only need short ones under 3” you can pound squares through progressively smaller holes in a metal bar.
-- No PHD just a DD214 Website> craftingcouple.com
View MrRon's profile
MrRon
5195 posts in 3446 days
#3 posted 06-19-2016 08:56 PM
This is a jig I use. Dimensions are not critical except that the piece with the holes drilled must be the same thickness as the wood to be doweled. That piece is made from a piece of scrap. The reason for the double sided design is: if the holes drilled are not perfectly straight (off by 1/2° for example), the holes won’t line up straight. In use, you would drill through from one side; then, without flipping the jig, drill the other mating wood piece. Even if the holes are off a tiny bit of an angle, they will still line up.
View BobAnderton's profile
BobAnderton
283 posts in 2993 days
#4 posted 06-19-2016 09:27 PM
Mrkixx, do you want a jig that will put dowel pin holes in a board, or a jig that will make dowels?
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View rick1955's profile
rick1955
264 posts in 1633 days
#5 posted 06-19-2016 11:29 PM
http://m.youtube.com/watch?v=1xF8H6wUiME
There’s other ways as well. The YouTube link will lead to others.
-- Working smarter with less tools is a true crafts person...
rick1955
#6 posted 06-20-2016 03:13 AM
http://www.startwoodworking.com/plans/dowel-joints-without-dowel-jig
How to Dowel without a jig…
Mrkixx
#7 posted 06-20-2016 06:19 PM
hi bob, a jig to make dowels or I guess a really good plug cutter set, and unfortunately I do not own a lathe
View ScottM's profile
ScottM
691 posts in 2349 days
#8 posted 06-20-2016 07:06 PM
I’ve done that in the ultra simple way of drilling a hole in a piece of scrap steel the same size as the dowel you want. Next trim down your blank using your table saw to a dimension slightly bigger than the needed dowel size. Use a utility knife and give the end a slight taper. Clamp the steel plate to your bench or put it in a vise. Chuck the blank into your drill. Place the tapered end of the blank into the hole in the steel plate. Then just drill away pushing the blank slowly into the plate. The plate will be sharp enough at the edges to shape the dowel.
I’ve done this several times and it works great. Easy, cheap, custom dowels made out your choice of stock.
BobAnderton
#9 posted 06-20-2016 08:44 PM
Ok, then check this out that Andy “galooticus” did. Also check out the woodgears link he gives.
