Is there any benchtop jointer worth having?
Forum topic by AZWoody posted 06-16-2016 04:46 PM 2644 views 0 times favorited 17 replies Add to Favorites Watch
View AZWoody's profile
AZWoody
1404 posts in 1373 days
06-16-2016 04:46 PM
I am needing to joint some smaller sized cutoffs for turning blanks and they’re too small to use on my larger jointer.
I could make some kind of sled for the tablesaw but there are so many small pieces, that will take a lot of time to do them all.
Is there a benchtop that will do a decent job with short pieces down to maybe 4”-6” or so in length?
17 replies so far
View ScottM's profile
ScottM
681 posts in 2295 days
#1 posted 06-16-2016 04:54 PM
My 6” bench top says the minimum length is 12”. I know it can go smaller, just depends on your skill and how much you like your fingers….
So it looks like a jig is your option for pieces that short. Now to decide whether that jig will be for your table saw or jointer….
View MrUnix's profile
MrUnix
6949 posts in 2348 days
#2 posted 06-16-2016 04:58 PM
You might want to consider something a little less high-tech:
Or perhaps a belt sander.
View TheFridge's profile
TheFridge
10360 posts in 1635 days
#3 posted 06-16-2016 04:59 PM
I’d just use the table saw and a push shoe.
View bbasiaga's profile
bbasiaga
1240 posts in 2144 days
#4 posted 06-16-2016 05:49 PM
Got a power planer? You could build a sled to hold the small pieces and do them all at once.
View devann's profile
devann
2246 posts in 2841 days
#5 posted 06-16-2016 07:46 PM
Do you have a router table and a fence with adjustable infeed/outfeed fence?
I’ve used mine for similar solutions to yours.
1. I use a 2” x 1/2” straight cut bit. Setup bit so the cutter is as close to the front edger of the table as possible.
2. Using a steel ruler for a straight edge and two thin washers of the same thickness, place the washers upright against the infeed fence.
3. Place the straight edge against the washers aligning the straight edge with the leading edge of the router bit cutter. Secure.
4. Move the outfeed fence to the straight edge and secure. The thickness of the washers will be your depth of cut.
It’s a kind of mini vertical jointer, but it works.
19088 posts in 2005 days
#6 posted 06-16-2016 07:59 PM
Any 6” jointer is going to be basically the same as far as distance between tables, so safety will not improve from your bigger jointer. I’m no turner, but do you really need to joint turning blanks? Unless you’re going to leave flat faces on your turning.
View Aj2's profile
Aj2
1732 posts in 1947 days
#7 posted 06-16-2016 08:27 PM
I dont think anything made and sold today is worth buying.
A handplane would be your best bet.But if that’s not your cup of tea.
Keep your eye out for a vintage 4 inch jointer.
Something like this.
-- Aj
View Lazyman's profile
Lazyman
2528 posts in 1536 days
#8 posted 06-16-2016 11:45 PM
I bought a used Porter Cable 6” bench top jointer off of Craigs List a few months ago for about $150. At first I had terrible buyers remorse because it was terrible. After looking at the setup a little more carefully, I realized that the blades were set too low and the blades were dull (probably because the previous owner used it to plane paint off an old board). I bought a new set of blades, set them to the proper height and it works like a dream for such a cheap tool. I’ve planned some hard hickory and gotten a finish ready surface. I also was able to plane as some hard as a rock live oak I milled myself. The chip collection works pretty well with just my shop vac. The worst thing about it is the fence is sort of difficult to get square buts once it is locked in, I don’t mess with it. The aluminum tables are not my favorite either but it works and they make it light enough to lift over my head to put on a shelf when not in use.
If you are going to use it frequently and have the room for one, bite the bullet and get a robust floor standing jointer. If like me, space is an issue and you just need something now and then, this is worth even the full retail price in my opinion.
BTW, I heard that the Grizzly 6” bench top is a little more robust than the PC so check it out too.
View teejk02's profile
teejk02
485 posts in 1274 days
#9 posted 06-17-2016 12:33 AM
I bought a used Porter Cable 6” bench top jointer off of Craigs List a few months ago for about $150. At first I had terrible buyers remorse because it was terrible. After looking at the setup a little more carefully, I realized that the blades were set too low and the blades were dull (probably because the previous owner used it to plane paint off an old board). I bought a new set of blades, set them to the proper height and it works like a dream for such a cheap tool. I ve planned some hard hickory and gotten a finish ready surface. I also was able to plane as some hard as a rock live oak I milled myself. The chip collection works pretty well with just my shop vac. The worst thing about it is the fence is sort of difficult to get square buts once it is locked in, I don t mess with it. The aluminum tables are not my favorite either but it works and they make it light enough to lift over my head to put on a shelf when not in use.
- Lazyman
Most of the “bench tops” don’t let you adjust anything other than depth of cut. Interesting to see that the typical jointer is also available in the mini version…I learn something every day.
AZWoody
#10 posted 06-17-2016 12:43 AM
I have hand planes as well, but some of these pieces are going to be a bit short to use a plane with. Also, I’m trying to avoid having to clamp things down to save some time. I’m wanting to be able to go through the scraps and flatten the side quick and make the cuts I need to save time.
I m no turner, but do you really need to joint turning blanks? Unless you re going to leave flat faces on your turning.
- firefighterontheside
Yes, straight edges are not important for turning but for me to cut my blanks, I need one straight edge and face so I can reference all my cuts.
I do like the idea of the belt sander. I could just put a low grit to make it quick and then do the cuts.
Lazyman
#11 posted 06-17-2016 12:53 AM
- Lazyman
Most of the “bench tops” don t let you adjust anything other than depth of cut. Interesting to see that the typical jointer is also available in the mini version…I learn something every day.
- teejk02
That’s correct. The only fine tuning you can really do is adjust the blade height. I spent an hour trying to see if there was a way to fine tune the out-feed table height because my first thought was that my initial problems were caused by the in-feed and out-feed tables tables not being coplaner before I realized that the blades were just set below the outfeed table (and very dull).
bbasiaga
#12 posted 06-17-2016 01:44 AM
The shopfox/grizzly bench top was a good machine for me. You could adjustry the tables for planar but it was a pain. Still, not safe to use on short pieces.
Could you glue the shorts end to end to make them long enough to joint, then cut the glue lines out?
View splatman's profile
splatman
586 posts in 1548 days
#13 posted 06-17-2016 06:02 AM
Clamp a hand plane upside down in a bench vise, along with a board (between the plane and the vise’s back jaw) to serve as a fence, and you now have a low-tech jointer that can handle short/small workpieces.
Cut a rabbet in the fence board so the board face covers the space between the plane’s side and the cutter.
Lazyman
#14 posted 06-17-2016 08:44 PM
Just to clarify. The 6” PC jointer manual says not to use it for anything shorter than 10”. That being said, I have used it with 6” boards with a hold down/push block that kept my hands well away from the cutter head.
View Bill White's profile
Bill White
5072 posts in 4109 days
#15 posted 06-17-2016 09:01 PM
I have a Cutech 6” benchtop jointer for just your needs.
Needed to finish a base for an antique angle level. Small job for sure, but the Cutech sure works well for the small jobs.
Bill
-- bill@magraphics.us
