Need help with a Jet Supersaw Left Tilting (JWSS-10LFR)
Forum topic by dredq posted 06-16-2016 02:35 PM 829 views 0 times favorited 2 replies Add to Favorites Watch
View dredq's profile
2 posts in 641 days
06-16-2016 02:35 PM
Topic tags/keywords: jet supersaw jwss-10lfr timing belt eccentric shaft elevating worm broken table saw tool repair
I purchased a used Jet Supersaw in excellent condition. It worked perfectly when I bought it. I brought it home in a truck without any problems. When I tried to raise the blade it would not raise. Opened up the saw and found that the upper Timing Pulley (#67) had fallen off. The silver shaft is the housing (Eccentric Shaft #28). Inside this shaft is the Elevating Worm (#25) which held the Timing Pulley. But now the Elevating Worm has moved into the Eccentric Shaft (silver shaft in picture) and now the Eccentric shaft is about 1/4” inside the housing. I need to get it out to connect the timing pulley. I have attached pictures an the schematic of the saw. Any ideas how to proceed? Thank you!
2 replies so far
View WhyMe's profile
995 posts in 1492 days
#1 posted 06-16-2016 07:06 PM
Can’t you push the worm shaft from the other end to get it to stick through where you can get the pulley installed?
2 posts in 641 days
#2 posted 06-19-2016 11:33 PM
Thanks for your suggestion. I was not able to do this….
But, I figured it out….just in case anyone else ever has this problem…
You need to flip the saw upside down…it takes the weight off the shaft… and then you can push it through… Simple solution…but if you do not flip the saw you will never get it to move.
