Warped table top is causing the frame to wobble
Forum topic by jonmakesthings posted 06-16-2016 01:24 AM 1477 views 0 times favorited 7 replies Add to Favorites Watch
View jonmakesthings's profile
jonmakesthings
73 posts in 961 days
06-16-2016 01:24 AM
I’m nearing the end of building a farmhouse style table. The top, which I haven’t attached to the frame yet, has breadboards which are doing a great job keeping it from cupping, but the top did still twist a little, it rocks when on a flat surface. My table frame is pretty solid and almost perfectly flat, it doesn’t rock at all. I’ve heard that if a top is slightly warped, securing it well to the frame will probably straighten it out. However when I attach the top to the frame, it does pull flat against the frame but in doing so slightly twists the frame, causing it to rock.
What would be the best way to go? The warp in the top isn’t really that bad, I can live with it, but it just causes the top to rock. I’m tempted to just secure it and then adjust the length of the legs to stop the rocking. Is there any real reasons why I shouldn’t do that? Or would that be a good way to go?
Thanks for your suggestions
-- How can you have any pudding if you don't eat your meat?
7 replies so far
View jumbojack's profile
jumbojack
1685 posts in 2767 days
#1 posted 06-16-2016 01:45 AM
Is there an apron? If so shim the bottom of the top so it does not rack your frame.
View bondogaposis's profile
bondogaposis
4986 posts in 2495 days
#2 posted 06-16-2016 01:59 AM
Tighten it to the frame and trim your long legs so that it is again flat on the floor.
-- Bondo Gaposis
jonmakesthings
#3 posted 06-16-2016 02:45 AM
Yes there are aprons on all 4 sides, attached with bridle joints
View sawdust703's profile
sawdust703
270 posts in 1563 days
#4 posted 06-18-2016 08:54 AM
Then do what Bondo said. It’ll be ALOT simpler.
-- Sawdust703
View jdh122's profile
jdh122
1038 posts in 2961 days
#5 posted 06-18-2016 09:47 AM
What Bondo said. With tables and chairs the normal procedure is to level it once everything is assembled.
-- Jeremy, in the Acadian forests
View pintodeluxe's profile
pintodeluxe
5757 posts in 2957 days
#6 posted 06-18-2016 05:29 PM
If the discrepancy is modest, I would use leg levelers. If you cut one leg shorter, what happens when the twisted top moves again with seasonal humidity changes?
Another option is to use felt pads under three of the legs. They will act as small shims to level the legs. The nature of felt allows it to compress where needed, and will naturally self level in a week or so.
View Loren's profile
10477 posts in 3791 days
#7 posted 06-18-2016 11:18 PM
You can scoop out material from the bottom using
hand planes to remove twisting stresses. The
solution is a bit exotic. I lay out an assembly
platform using levels and shimmed milk crates.
You can get the legs and skirt nearly perfectly
level this way on 4 corners. Put the top on
top, clamp it down and see if it pulls a corner up.
