Panel Cap angle in wainscoting
Forum topic by simsim posted 06-14-2016 04:05 PM 729 views 0 times favorited 5 replies Add to Favorites Watch
View simsim's profile
simsim
1 post in 796 days
06-14-2016 04:05 PM
I do basic work around house (honey do’s) but never really had to deal with angles (especially panel caps).
I have installed the stiles/rails (everything is square) but I cannot seem to find angle at which I should cut the panel cap to make it fit. Please refer to attached images for details and molding profile.
I do have a Dual-Bevel Glide Miter Saw.
5 replies so far
View MadMark's profile
MadMark
979 posts in 1537 days
#1 posted 06-14-2016 04:17 PM
Use a piece of scrap rail as a guide block and set your moulding notch square on the block. Cut as standard 45° moulding.
M
View TheFridge's profile
TheFridge
9860 posts in 1570 days
#2 posted 06-14-2016 04:29 PM
You are going to have to let it sit flat in the panel.
View jbay's profile
jbay
2490 posts in 983 days
#3 posted 06-14-2016 04:50 PM
Looks like maybe your molding is adjustable for different thicknesses of panels?
Normally the two flat sides that go against your panels are parallel and you buy the molding for the thickness of your panel. Anyways, you can do this.
Put a block the same thickness as your panels
then set your molding on the block (just as it would be on your panel)
Set you saw at a 45 and cut either left or right side.
View pintodeluxe's profile
pintodeluxe
5736 posts in 2897 days
#4 posted 06-14-2016 05:02 PM
1+ with jbay’s solution. Kind of like setting the spring angle when cutting crown molding.
I might even make a two-piece stop block to keep the molding from sliding towards the fence as you cut it.
View nickbaker's profile
nickbaker
3 posts in 695 days
#5 posted 09-23-2016 09:26 AM
Thanks to this, maybe it is time for me to repair and modify my old door to this one. I have this old front door that I bought years ago at http://caldwells.com/ and now there is slight issues however needs some repair.
