Reclaiming an old 1HP motor from a pool pump...
Forum topic by A. Michael Wilson posted 04-22-2010 05:02 PM 928 views 0 times favorited 2 replies Add to Favorites Watch
View A. Michael Wilson's profile
A. Michael Wilson
7 posts in 2901 days
04-22-2010 05:02 PM
Long story short, I have an extra pool pump with a cracked skimmer basket. It looks like the whole thing has been left outside for years, but the motor still works fine. My thoughts were to build a bench grinder with the motor. Seems straight forward enough.
Has anyone used a pool pump motor to run wood working stuff? Does anyone know any reason why it would be a bad idea?
2 replies so far
View Michael Murphy's profile
Michael Murphy
453 posts in 2934 days
#1 posted 04-22-2010 07:31 PM
Pump motors tend to have different shaft types than regular C frame motors because of the way they attach the impellers, also the mounting might be different. If you can make fit, mount it, and put a pully on it securely, I don’t see why you couldn’t use it to power a grinding wheel on an arbor or a lathe or whatever.
-- Michael Murphy, Woodland, CA.
18224 posts in 3605 days
#2 posted 04-22-2010 07:32 PM
not as long as you make it secure. no wheel flying around ;-))
