Waterproof wood glue?
Forum topic by crank49 posted 04-22-2010 12:47 AM 19068 views 0 times favorited 17 replies Add to Favorites Watch
View crank49's profile
crank49
4029 posts in 2872 days
04-22-2010 12:47 AM
I’m lookin for a good waterproof structural wood glue. I’ve seen about a gazillion comments about Titebond glue; seems like everyone on LJ uses the stuff. But, it’s not waterproof is it? I know Gorilla glue is waterproof, but don’t like the foam-out. Seems like I remember a glue, from years ago, that you used to have to mix a powder with water then clamp overnight. That stuff was used to glue airframe parts together I think. It might have been called Hyde glue. Anybody know what I am talking about? What is it? Anything out there better today?
17 replies so far
View bobasaurus's profile
bobasaurus
3376 posts in 3085 days
#1 posted 04-22-2010 01:02 AM
Titebond 3 is waterproof: http://www.titebond.com/WNTitebondIIITB.asp
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View Michael Murphy's profile
Michael Murphy
453 posts in 2906 days
#2 posted 04-22-2010 01:05 AM
Weldwood Plastic Resin Glue
Hide glue is Hide glue you mix with water and heat. Made from animal by products. Strong stuff but it stinks and attracts rodents.
You can stil get it though. Check here
-- Michael Murphy, Woodland, CA.
View jcsterling's profile
jcsterling
462 posts in 3486 days
#3 posted 04-22-2010 02:07 AM
Weldwood marine resorcinol glue. 2 part glue 100% waterproof and weatherproof. Dries very dark.
http://www.dap.com/product_details.aspx?BrandID=64&SubcatID=10
-- John , Central PA , www.jcsterling.com on facebook: http://www.facebook.com/#!/pages/JC-Sterling-fine-furniture/104430802928776
View Knothead62's profile
Knothead62
2581 posts in 2862 days
#4 posted 04-22-2010 02:09 AM
I used Titebond III for building fishing rods- gluing the cork rings together for the grip.
View Gofor's profile
Gofor
470 posts in 3688 days
#5 posted 04-22-2010 03:55 AM
Don’t overlook construction glue like Liquid Nails. Short work time, but can be had formulated for treated lumber, etc, for outdoor projects.
The DAP Weldwood 2 part plastic resin will also hold up to about any environment. Some things my dad used it on back in the 1960’s were still holding strong in the 1980’s.
That said, I have never had Titebond III give up on any outdoor furniture, or anything I have built subjected to stove steam/heat yet, but that’s only after about 3 years or so.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View Les Hastings's profile
Les Hastings
1305 posts in 3674 days
#6 posted 04-22-2010 04:40 AM
West Systems two part marine epoxy.
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
Michael Murphy
#7 posted 04-22-2010 06:44 AM
He was asking about a powdered glue mixed with water. That would be the Weldwood (or other brand) Plastic Resin glue. I used it all the time for bent laminations or any time I did not want a flexible bond like a PVA glue (titebond) or the expense and trouble of an epoxy. It is an economical and practical solution to a need for a bit of waterproof glue. I think you could probably still buy a small plastic pail of Plastic resin glue, probably makes a cup of the glue for small jobs. I no longer have a working cabinet shop but we used to keep a 5 or 10 lb bucket on hand. If it was kept dry (california climate) it lasted a long time in the sealed (or even opened and reclosed) bucket. Mixed, it cures in an hour or so.
View Viking's profile
Viking
880 posts in 3096 days
#8 posted 04-22-2010 06:15 PM
+1 for the Titebond III and you can buy it for big savings at Harbor Freight.
Picked up a 4 oz bottle a couple weeks ago at HF and they only charged me $.99. Didn’t notice until I got home and took a better look at my receipt. Thought it might be a mistake so went back next day and sure enough bought three more for $.99 each.
Good Luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View wiswood2's profile
wiswood2
1138 posts in 3597 days
#9 posted 04-22-2010 06:41 PM
I use notghingt butg tgitge bond 2 or 3 2 is water resint and 3 is water prof neer had itg let gto yetg I ha e used it for 20 + years.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
crank49
#10 posted 04-22-2010 06:46 PM
Thanks everyone. I think the plastic resin Michael pointed out is exactly what I was thinking about. Went to Dap’s website, i see it’s a urea formaldahyde formula and that struck a bell.
Thanks again.
View Planeman's profile
Planeman
97 posts in 3479 days
#11 posted 04-22-2010 09:56 PM
The Weldwood marine resorcinol glue is used for homebuilt aircraft construction so it should fill your needs. I used it building a biplane years ago. The only negative is it has a strong reddish-brown color when it is cured so this might be a problem on light wood. It comes in two parts, a powder and a liquid. You mix the two together by volume.
Rufus
-- Always remember half of the people in this country are below average.
Viking
#12 posted 04-27-2010 03:27 PM
Correction;
The Titebond III at Harbor Freight was 8 oz. bottle for $.99 not 4 oz.
View Rusty108's profile
Rusty108
1 post in 1295 days
#13 posted 08-01-2014 09:20 PM
This is an old thread but if it helps, this site has a good summary of wood glues and lists some waterproof ones
www.gluehow.com/recommendation/Wood/to/Wood
Also seen the resorcinol glue mentioned in this thread recommended often.
View Ger21's profile
Ger21
1074 posts in 3032 days
#14 posted 08-02-2014 02:31 AM
He was asking about a powdered glue mixed with water. That would be the Weldwood (or other brand) Plastic Resin glue. ................................................................................. If it was kept dry (california climate) it lasted a long time in the sealed (or even opened and reclosed) bucket. Mixed, it cures in an hour or so.
- Michael Murphy
In a not so dry climate, the powder only has a shelf life of about 1 year.
And it takes about 12 hours to cure at 70°, and shouldn’t be used if it’s much colder than that. The hotter it is, though, the faster it will cure.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
4868 posts in 2394 days
#15 posted 08-02-2014 11:26 AM
I believe that the resorcinol is the only truly waterproof glue, though the UF glues are highly water resistant. Resorcinol is actually submersible, which makes it the only one(except maybe some epoxies), I think.
