How much to spend to get a good chisel set?
Forum topic by itsme_timd posted 344 days ago 282 views 0 times favorited 16 replies Add to Favorites
View itsme_timd's profile
itsme_timd
504 posts in 359 days
344 days ago
Topic tags/keywords: question chisel
Right now I’ve got a $2.00 Wally-World chisel that won’t sharpen so I know I need a better set.
I’ve seen them run anywhere from the $2.00 set to $300.00 sets. Well, I don’t have $300.00 to spend on chisels but wanted to know what a good brand, price, etc. is for chisels. I saw a Buck Bros. set for $20.00 and an Irwin set for $40.00 (4 in each set) and then there’s the Lie Nielsen set…
-- Tim D. - Woodstock, GA
View Thos. Angle's profile
Thos. Angle
3409 posts in 491 days
344 days ago
I just got a set of $29.95 Marples at HD. They seem about average. I got them to beat the crap out of. The Irwins, which used to be Marples, were Frank Klauss’ pick a while back. They’re the blue handled ones. I would go with them and give them a try. If they don’t work you aren’t out a fortune.
View Red Headed Merganser's profile
751 posts in 702 days
344 days ago
The Irwin/Marples set w/the blue handles are a good beginner (intermediate, advanced) set and won’t break the bank. They’ve been reviewed well by Woodworking Magazine and Frank Klausz.
If you can find a Woodcraft near you, they usually have six or eight piece boxed sets (for $65 and $85, respectively, sans shipping). If you don’t have one near you, you can still get them on-line, but you’d have to pay a little more for the shipping charges. That would give you a complete set, with a storage box, that would last you through many years of woodworking.
-- Ethan, http://www.merganserwoodworks.com, http://greystonegreen.blogspot.com/
View Peter O's profile
Peter O
669 posts in 403 days
344 days ago
I picked up the same set as Thos this summer. I’ve been pleasantly surprised at the quality. Certainly not the best chisels you could own, but really pretty good. Rockler has them on sale right now, although with shipping you might just go to the BORG.
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
itsme_timd
344 days ago
Thanks guys. I actually do have a Woodcraft store close by and will check that out.
View Dadoo's profile
Dadoo
1549 posts in 519 days
344 days ago
Got a 6 pack set from Craftsman Professional for like, around $30.00. Surprisingly, they’ve held up for over two years of use. They take and hold an edge well too. Gave my old Stanley 3 pack set to my son as he had at one time used them to cut a bolt on his car. Had to do some serious grinding on that particular one but it’s good to go again. The biggest thing to look out for is that the metal goes all the way thru the handle ending in a “striking head”. The Stanleys don’t and the handle will eventually come apart.
Here’s the Craftsmans link: http://www.sears.com/shc/s/p_10153_12605_00936866000P?vName=Tools&keyword=wood+chisel
View Mike Lingenfelter's profile
Mike Lingenfelter
403 posts in 642 days
344 days ago
I have a couple Irwin/Marples and they are good. I also have some from Lie Nielesn, and they hold their edge for a very long time. You get what you pay for, most of the time. I couldn’t afford a whole set from Lie Nielesn either, so I buy 1 or 2 every so often.
-- http://theinquisitivewoodworker.com/
View gizmodyne's profile
gizmodyne
1479 posts in 618 days
344 days ago
Ditto on the marples. They can handle abuse. I know they have been redesigned though. I have not used the new style.
itsme_timd
344 days ago
I grabbed a 4 piece Marples set at HD yesterday – I’m going to start a project today that will allow me to try them out.
gizmodyne
344 days ago
You probably will need to sharpen them.
itsme_timd
344 days ago
So these need sharpened from brand new, is that correct?
13167 posts in 929 days
344 days ago
Yes Too bad. Unless you but the best Japanese chisels You have to sharpen them
View DAN's profile
DAN
3461 posts in 511 days
344 days ago
Irwin/Marples work good for me too !
-- ..... art for lifes sake ... danwalters@lumberjocks.com
View Harold's profile
Harold
294 posts in 376 days
344 days ago
You will need to clean up the edge before you begin, but stones are an investment also. What you can do is stop by a napa or automotive paintstore and by a few sheets of wet sand paper, I would get 400, 600, 800, and 1200. and glue them to a flat surface, I use a sheet of lexan I got at HD. The area that most neglect when sharpening is the back so you have to pay attention to the back as well as the bevel. When you are working the back you can use some pressure, but when working the bevel your focus must be on keeping your bevel flat to the surface. For example I will make 25 passes on the back and then 50 on the bevel, and Progress thru the grits. Now my budget it somewhat challenged, but I bought a felt wheel and arbor from traditional woodworker or maybe lee valley, can’t remember. It is a kit the have that included a little mount to clamp a hand drill to your bench or whathaveyou. WHAT A TIME SAVER! whenever I feel alittle resistance I just hone the back and bevel for a few seconds and keep going, if you can keep them sharp it makes such a difference. the first time sharpening will take some time but go slowy it wil take about 5 minutes per chisel to finish the edge. Now whatever you do, once you have them sharp, DON’T PRY, I chiped the corner off a new parting chisel the first day, I knew what I was doing was wrong, but i was sure I could pop that chip out, needless to say that broken corner will be there for years, a shiny reminder not to pry.
and on that little honing kit for the drill, it came with three soft wheels, but use a hard felt wheel to hone you will have to rig up a bushing to get it mounted to your drill, shoot with alttle thought you could rig up the entire set up, I like it because it’s small and it will run off the small invertor in my truck when I’m out at south point waiting for bell to ring on my fishin pole
-- If knowledge is not shared, it is forgotten.
itsme_timd
344 days ago
Some great input here, thanks again to everyone – you’ve all been a big help!
Thanks!
View Wooder's profile
Wooder
163 posts in 715 days
341 days ago
One more comment Tim. I have an “old” set of Marples and a new set of Irwins, a bunch of old re-habed flea market ones also. I use all these for everything, except mortice work.
This is where IMHO, you should get picky. Most of my mortice work is 1/4 or 3/8, soooo I got a Robert Sorby registered mortice chisel for those sizes. Got as much in those 2 as I do all my others. But that way you only buy the hi $$$$ ones for what you need.
2 cents
BTW got the Irwins new on the bay for $28 including shipping. Was a deal…
-- Jimmy
itsme_timd
341 days ago
Thanks again for the input, I’ve learned a lot in a short span of time thanks to this board.
I got a stone and sharpened the Marples set ($30 at HD) and to me these seem excellent, I can literally shave off the wood with these.
Bookmark And Share This Page
