Custom shelving
Forum topic by jumbojack posted 06-10-2016 03:10 AM 823 views 0 times favorited 7 replies Add to Favorites Watch
View jumbojack's profile
jumbojack
1685 posts in 2861 days
06-10-2016 03:10 AM
I was installing some custom shelving in a linen closet. I measured the exact width of the shelf opening front and back. Luckily they only varied a 16th to 3/32. They did however vary from the top shelf to the bottom shelf by 7/32”. I ended up cutting them all 3/32” less than the measured size with a 5* bevel. It allowed the shelf to drop right in with about a 16th gap over all. That’s a 1/32” on each side which was nearly invisible. .
I did not arrive at this on the first go round. Try it you’ll like it.
7 replies so far
View Jim Jakosh's profile
Jim Jakosh
21961 posts in 3343 days
#1 posted 06-10-2016 03:29 AM
Good idea, Jack!!
Jim
View MadMark's profile
MadMark
979 posts in 1690 days
#2 posted 06-10-2016 03:41 AM
I cut this three times and it’s STILL too short!
M
View Jerry's profile
Jerry
2923 posts in 1885 days
#3 posted 06-10-2016 05:46 AM
That is really using the old noggin’ congratulations on snarfling the Garthock!
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View AandCstyle's profile
AandCstyle
3185 posts in 2494 days
#4 posted 06-10-2016 11:05 AM
Hey, Jack, thanks for the tip. I am going to be making new treads and risers to go over the existing ones and will use this method to ensure a great fit without bunging up the stringers.
-- Art
View JoeinGa's profile
JoeinGa
7739 posts in 2244 days
#5 posted 06-10-2016 12:01 PM
Good doing Jack..
“Measure TEN TIMES , cut once.” (author unknown) Words to live by :-)
View johnhutchinson's profile
johnhutchinson
1243 posts in 1866 days
#6 posted 06-10-2016 06:29 PM
I think you reinvented the door trick.
The strike edge of a man door is always beveled by 5 degrees so the edge of the door doesn’t hit the jamb.
The margin around the door is constant, and the bevel is hidden by the stop.
Done learned that in arkitec school. :-)
GREAT TIP !!!
-- John - Central Ohio - "too much is never enough"
View Roger's profile
Roger
20965 posts in 3041 days
#7 posted 06-12-2016 01:02 PM
Gr8 tip JJ. I always seem to make things too tight. I need to allow a lil more space
