How do I cut a 60 degree bevel on a table saw
Forum topic by Dyidawg posted 04-20-2010 06:06 AM 19472 views 0 times favorited 3 replies Add to Favorites Watch
View Dyidawg's profile
Dyidawg
51 posts in 3035 days
04-20-2010 06:06 AM
Hi all,
A silly question for the group. I have a 12” x 5” piece of 3/4” plywood. The plan I’m working on states that one end is to be cut at 30 degree for attachment to a vertical wall and 60 degree for the bottom wall. I have already made the 30 degree cut but I’m not sure how to do the 60 on the table saw. Do I need a jig to do this? Any help is appreciated.
-- Wow, that was easy. Just follow the directions and use some common sense.
3 replies so far
View Brandon Hintz's profile
Brandon Hintz
53 posts in 3031 days
#1 posted 04-20-2010 07:08 AM
I made a simple jig using 2×4’s and my miter fence basicly you need to hold the piece of plywood perpendictular (90) to the table and set the tablesaw to 30 that will give you a 60* cut a piece that small would probably work in a tenoning jig
-- Potential is limited only by imagination
View kolwdwrkr's profile
kolwdwrkr
2821 posts in 3613 days
#2 posted 04-20-2010 07:33 AM
most of the time you run the material flat on the saw. this allows you to cut up to 45 or a little more. Stand the piece on edge and you can cut a much greater angle. If you need to make a jig that rides along the fence that you can clamp your project piece to. Good luck
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3735 days
#3 posted 05-18-2010 12:53 AM
Flip it over and cut a 30 degree angle? The complementary angle of 30 is 60….
