Who knows how to make a saw handle
« back to Hand Tools forum
Forum topic by Marn64 posted 06-09-2016 11:37 PM 705 views 0 times favorited 6 replies Add to Favorites Watch
View Marn64's profile
295 posts in 715 days
06-09-2016 11:37 PM
Topic tags/keywords: question
Hey everybody,
so 2 days ago, I got a couple Disston saws from my local Restore. Well I have been trying my best, but I couldn’t save the original handle on the 1877 one (the other was a late 40’s early 50’s). The wood is dehydrated, cracked, dusty and every time I’ve tried to epoxy a crack, it won’t set. So I’ve all but given up on the saw handle and was wondering if anyone could make a new one for me or could instruct me how to.
-- Benjamin, Milwaukee
View JayT's profile
5536 posts in 2141 days
#1 posted 06-09-2016 11:45 PM
It’s not that hard, if you start with a template. Two Guys in a Garage has a bunch of handles scans that will get you started. A drill press and some kind of saw to do curves (bandsaw, scroll saw, coping saw) and you are on your way. Shaping can be done with a router and rasp or even just sandpaper, if you are patient. Quarter sawn lumber is preferred for saw handles.
View Johnny7's profile
353 posts in 1020 days
#2 posted 06-10-2016 01:41 AM
+1 to JayT’s remarks
Also, well-known LJ saw afficianado Summerfi has a tutorial HERE which you may find useful
View Jim Finn's profile
Jim Finn
2637 posts in 2852 days
#3 posted 06-10-2016 10:08 AM
View Homick's profile
23 posts in 1851 days
#4 posted 06-13-2016 04:51 PM
I have made a handle. The TGIAG is a great place to get a template (make sure you print it without scaling). My process was as follows:
1. Print the template
2. glue it to the wood (I would recommend stock a bit proud of 3/4” up to 1” thick for bigger hands)
3. Drill out the indicated holes. Also drill your holes for the sawplate and nuts
4. Cut your kerf for the sawblade first (because it’s the hardest part to get right and if you screw it up, you didn’t waste much time on it)
5. Start rough removal, leaving about 1/8th” around the border
6. Shape to the border with whatever you have (I use almost ever form of shaping tool you can think of because of all the grain directions and surfaces you are trying to form on a handle
7. Shape the curved edges, rough with rasps, sandpaper strips for finishing
8. Scrap/sand off the paper template if it hasn’t already peeled off.
One of the more difficult tasks I’ve undertaken (no bandsaw or scroll saw here); each step could be chapter in a book. Getting the right shape for your hand is a subtle task … I found using a router for the edge treatment makes it look generic and cheap.
#5 posted 06-13-2016 08:32 PM
Thanks for the info everyone!
View BigYin's profile
406 posts in 2346 days
#6 posted 06-13-2016 09:36 PM
have you looked on ebay for saw handles ? there are several on tonight
-- ... Never Apologise For Being Right ...
