Delta belt sander hump/ridge in middle of belt?
Forum topic by Jmdowdy posted 06-09-2016 06:17 PM 1111 views 0 times favorited 10 replies Add to Favorites Watch
View Jmdowdy's profile
Jmdowdy
3 posts in 905 days
06-09-2016 06:17 PM
Topic tags/keywords: 31-695 delta belt sander 6x36 belt sander hump ridge question
I have a Delta 31-695 6”x36” belt sander. It’s been a decent machine for several years now. Recently the belt has started forming a hump/ridge in the middle of the belt around the circumference. See the attached photos. Both photos were a top down view of the belt, one includes a straight edge so you can see that the hump is quite pronounced. I thought it was a bad belt so I replaced it with another perfectly flat belt only to have it do the same thing after a few weeks. I can’t find any noticeable problem with the end rollers. Everything runs smoothly, but this hump makes sanding wide pieces nearly impossible. Has anybody experienced or heard of this problem? What should I check for to eliminate this issue? Thank you.
10 replies so far
View MadMark's profile
MadMark
979 posts in 1631 days
#1 posted 06-09-2016 10:13 PM
Replace the belt, waxing the bed before putting the new one on. Double check your rotation arrows as you install. All else fails its time to buy a newer, better one.
M
View TheFridge's profile
TheFridge
10515 posts in 1664 days
#2 posted 06-09-2016 10:35 PM
It’s where the belt stretched it looks like. Not much you can do aside from replacing.
runswithscissors
2875 posts in 2203 days
#3 posted 06-09-2016 10:50 PM
2 possible causes I can think of: You might have concentrated pressure on the middle of the belt for an extended period of time, which could have heated it up and stretched it. Or, the crown in the rollers is causing that—but I don’t know why it would, as these sanders typically have crowned rollers, and it’s not a problem I have ever noticed.
You also mentioned that the hump showed up after a few weeks, which suggests my first idea might be right. Also, the belt looks well used, and it may just be tired out. I sag like that when I’m tired too.
View cabmaker's profile
cabmaker
1740 posts in 2987 days
#4 posted 06-09-2016 10:51 PM
That is an inherent problem with non oscillating sanders. Its a hot spot…..just indicates you actually use the sander.
You might extend the belt life a bit by layering up your platform with random thicknesses to give that hot spot some relief.
Enjoy JB
View Woodknack's profile
Woodknack
12402 posts in 2558 days
#5 posted 06-10-2016 01:28 AM
Belts are consumables.
Jmdowdy
3 posts in 905 days
#6 posted 06-10-2016 03:24 AM
Thanks for the response. The new belt hasn’t seen much use since I installed it. It sat mostly idle before I noticed the same hump as the first belt. I’ll buy another belt next time I’m at the hardware store and give it another try this time taking note of how hard I’m using it and to try and avoid hot spots that would compromise the belt.
Enjoy JB
- cabmaker
View oldnovice's profile
oldnovice
7275 posts in 3546 days
#7 posted 06-10-2016 03:34 AM
From my experience it appears that the belt has gotten wet!
I have seen that as my belt sander is outdoors and at one time the cover was not on correctly; I noticed moisture on the middle of the belt and after it dried a warp/bubble formed in that area.
That’s my story and I am sticking to it!
View devann's profile
devann
2246 posts in 2870 days
#8 posted 06-10-2016 06:10 AM
Are you using a belt sander cleaner?
Jmdowdy
3 posts in 905 days
#9 posted 06-10-2016 06:29 AM
On occasion, as needed, I have.
- devann
View bondogaposis's profile
bondogaposis
5057 posts in 2529 days
#10 posted 06-10-2016 12:48 PM
Try a different brand of belts.
-- Bondo Gaposis
