steam bent or bandsaw-ed?
Forum topic by Tim posted 1125 days ago 712 views 0 times favorited 3 replies Add to Favorites Watch
View Tim's profile
Tim
43 posts in 1346 days
1125 days ago
Topic tags/keywords: teak tip bandsaw bending
I’d like to attempt to reproduce this as a 10th Anniv gift for my better half.
http://www.mainecottage.com/ProductDetail.aspx?prodType=1&cat=218&prod=1247&step=PRODUCT
Do you think the apron is steam bent or just cut from a wider stock? This would be my first attempt at Teak so I’m trying to size up the difficulty of the build let alone the material.
thanks
3 replies so far
View Rick L's profile
Rick L
511 posts in 1927 days
#1 posted 1125 days ago
Laminate bent from 1/8” strips is the easy way with a proper glue to eliminate springback would be my 1st choice. Steaming teak is not an easy way to start with bending.
Bandsawing from thicker stock would be the simplest for you and no one else will know but you.
Teak is very difficult wood to joint and plane with High Speed Knives. The Minerals dull the metal fast. You will go through a bandsaw blade or two. Carbide circular saw blades will last the longest.
-- Few folks really know how to maximize the potential of their tools!
View UnionLabel's profile
UnionLabel
660 posts in 1366 days
#2 posted 1125 days ago
Be alot of waste I thing for bandsaw cut. My guess is resaw thin slices then glue and press them in a form. Laminated is strongest. Got to build the press any way for steam bent. I’d make the press out of a couple of hunks of 2 X 12 and 3/4 inch ply, cut the radius I need sandwich the ply between the 2 X 12’s, wax it up, then glue up the thin pieces and clamp the bajesus out of the thing over night.
I was going to build a steam tank at one point, but decided against it. Resaw and laminating is what I believe works the best.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View Michael Murphy's profile
Michael Murphy
448 posts in 1171 days
#3 posted 1125 days ago
Teak would not be a good choice to steam bend anyway. The Bent Lamination would be the way to go. Make sure you use a rigid glue like resorcinol, or Marine glue that you mix up with water. PVA glue is too flexible.
-- Michael Murphy, Woodland, CA.
