1/2 to 1/4 router shank adapter
Forum topic by tchara posted 06-07-2016 08:41 PM 673 views 0 times favorited 4 replies Add to Favorites Watch
View tchara's profile
33 posts in 673 days
06-07-2016 08:41 PM
Topic tags/keywords: question
I’m in the middle of installing a router table in the wing of my Delta 36-725. I have a brand new Sears router that came with a table and other router installed in it. The extra router I plan on using, I discovered is 1/2 shank. All my bits are 1/4 inch. Does anyone have any experience with any adapters out there that work, or should I start looking for sales on 1/2 router bits?
View Lazyman's profile
1810 posts in 1317 days
#1 posted 06-07-2016 08:48 PM
Most routers these days that can handle 1/2 bits also come with a collet for both 1/2 & 1/4” shanks so hopefully, you’ll be able to find one for your router.
EDIT: Try to find the part number for your router. That might not be the cheapest price but might help you find the right one.
View bondogaposis's profile
4629 posts in 2281 days
#2 posted 06-07-2016 10:07 PM
Get a quarter inch collet for your router.
-- Bondo Gaposis
View HokieKen's profile
4653 posts in 1068 days
#3 posted 06-08-2016 03:20 PM
I’ve tried a 1/4” adapter that goes in the 1/2” collett and it worked pretty well but on heavy blind cuts, like dadoes, it seemed to let the bits climb a little bit. I now have 1/2” and 1/4” colletts for both of my routers. They were inexpensive and well worth the cost to eliminate the extra piece in the setup.
I now only buy 1/2” shank bits though. The extra “beef” makes for a better cut. So my advice is to get a 1/4” collett (not adapter but a seperate collett) and use the 1/4” bits you already have but buy 1/2” ones going forward.
If you can’t find a reasonably priced collet for your particular router, get a good quality adapter like this one.
-- Kenny, SW VA, Go Hokies!!!
View xeddog's profile
179 posts in 2937 days
#4 posted 06-08-2016 04:11 PM
I have had to use a 1/2” to 8mm adapter for use with my dovetail jig. The only problem I noticed was that I had to tighten the collet a lot more. The first time I used it, I was routing a 6” wide board for testing and then I noticed that things didn’t sound right. The router sounded like it was running without a bit. Guess what? I t was running without a bit.
