Need a shorter fence for my Sawstop ICS
Forum topic by daveshilling posted 06-07-2016 05:20 PM 1227 views 0 times favorited 14 replies Add to Favorites Watch
View daveshilling's profile
daveshilling
48 posts in 831 days
06-07-2016 05:20 PM
Topic tags/keywords: sawstop fence
If any Northern California SawStop ICS owners would like to swap, I have a 52” Shop Fox W2006 fence and a non-Sawstop Mobile base that came with my recent used Sawstop purchase. It’s much too large for my garage, and a 36 would give me space to walk by the saw (=
I know it’s a slim chance that someone is out there wanting to trade, but what the heck, I’ll give it a shot!
Or if someone is selling their Sawstop 36” setup, I’m interested.
Options I’m avoiding for now:
cutting the rails
buying shorter shop fox rails ( cant find any)
buying an Incra
14 replies so far
View UpstateNYdude's profile
UpstateNYdude
917 posts in 2038 days
#1 posted 06-07-2016 08:23 PM
You could buy the VSC (Very Super Cool) tools fence and add any size aluminum extrusion you wanted.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View DBordello's profile
DBordello
132 posts in 1282 days
#2 posted 06-07-2016 11:12 PM
I have a 36” kit for the PCS, I am not sure if it is compatible. I have been looking to exchange it with someone for the 52”.
For what it is worth, I am in Oregon.
View CyberDyneSystems's profile
CyberDyneSystems
288 posts in 2244 days
#3 posted 06-08-2016 04:06 PM
- DBordello
SawStop is saying that the two (ICS rails and PCS rails) are not interchangeable.
That said, YOU can buy SawStop fences from any SawStop dealer.
-- Without the wood, it's just working
View builtinbkyn's profile
builtinbkyn
2529 posts in 996 days
#4 posted 06-08-2016 04:22 PM
Why can’t you just cut the rail shorter? Or just buy some steel tube stock and cut it to size and hold onto the SS tube for later use should you have room for a longer extension.
-- Bill, Yo!......in Brooklyn & Steel City :)
daveshilling
#5 posted 06-08-2016 07:09 PM
- UpstateNYdude
Thanks for this new option! I’m checking it out. Does anyone in the greater Sacramento area have this fence system that I can experience in person?
daveshilling
#6 posted 06-08-2016 07:12 PM
- DBordello
- CyberDyneSystems
Thanks for that clarification. I figured that if Incra charges extra to modify their fences for the ICS, they must be different, and you have confirmed this. Yeah, I can pay retail plus their inflated shipping and handling, but I’m looking for a mutually beneficial option first…if I can just swap with a fellow wood jockey and make a new friend, I’ve come out ahead!
daveshilling
#7 posted 06-08-2016 07:21 PM
Why can t you just cut the rail shorter? Or just buy some steel tube stock and cut it to size and hold onto the SS tube for later use should you have room for a longer extension.
- builtinbkyn
Oh, I can cut the rail, but that rail is now worth much less. I don’t know if it’s odd to do so, but resale value is something I take into consideration when buying tools. Besides, if someone locally can use the rail as-is, that’s the best option. I’d rather buy a shorter rail as you said. Ideally, a Sawstop OEM solution would be my first choice since they designed it with their own saw in mind.
The long route is to just buy the ICS fence and sell mine at my leisure, which I would do if a used ICS fence setup appears.
builtinbkyn
#8 posted 06-08-2016 07:36 PM
Well here’s a relatively inexpensive option. Probably won’t be much bidding on this. Says 30” but rules to 34” to the right of the blade. Good luck which ever way you go. Ebay link
CyberDyneSystems
#9 posted 06-09-2016 04:53 PM
If you are agaisnt simply cutting your rails down, ICS Fence Rail is standard 3” x 2” steel tube. (As is Beisemeyer) They use it for steel door frames, so it’s really common.
You can get it in a few gauges, the lighter 3/32” gauge is what I think most fence manufacturers use (SawStop and Beisemeyer to name a few) but some people will jump up to 3/16. This would be a very affordable alternative to cutting your rails.
Of course you would also need to get the angle iron, (3” x 2.5” front, 2.5” x 2” rear) and do all that drilling and notching,.
Cutting your rails would be the easiest and cheapest solution.
Can you say “Portaband”? :) Do it right in place, 10 minute job, no need to remove anything. ;)
CyberDyneSystems
#10 posted 06-09-2016 05:00 PM
Well here s a relatively inexpensive option. Probably won t be much bidding on this. Says 30” but rules to 34” to the right of the blade. Good luck which ever way you go. Ebay link
- builtinbkyn
Shoot, other than shipping costs, that’s a sweet deal! At least the only possible drilling would be the attachment points to the ICS table, the rest (which is a lot) is done.
builtinbkyn
#11 posted 06-09-2016 07:32 PM
Agree. Thought it was a pretty good option, price considered and it comes with the angle irons so no need to cut the OEM SS irons. Holes may or may not align, but that’s an easy fix.
- builtinbkyn
Shoot, other than shipping costs, that s a sweet deal! At least the only possible drilling would be the attachment points to the ICS table, the rest (which is a lot) is done.
- CyberDyneSystems
View Bear1219's profile
Bear1219
10 posts in 835 days
#12 posted 06-10-2016 01:57 AM
I have a 36” kit that I removed from my saw I can sell you. You just need to figure out how to rig it and make it work with your saw. I replaced my fence with the Incra fence. Also have an extra cast iron wing and the black table from the saw as well since I had to remove it to install their router table.
daveshilling
#13 posted 06-10-2016 02:39 AM
If you are agaisnt simply cutting your rails down, ICS Fence Rail is standard 3” x 2” steel tube. (As is Beisemeyer) They use it for steel door frames, so it s really common.
- CyberDyneSystems
You had me at 10 minute job! Thanks for all of the info! That definitely helps out. For some reason, metal hates when I try to drill it. I can’t seem to figure that out. oil, going slow, etc… I just suck at it.
daveshilling
#14 posted 06-10-2016 02:42 AM
- Bear1219
Thanks for the offer! Since your saw isn’t the industrial version, the fence is different, but I do appreciate it!
