Request Tutor (say 1-2 hours) in Washington, DC area on Jet 14" Band Saw
Forum topic by GJK posted 06-06-2016 08:15 PM 802 views 0 times favorited 1 reply Add to Favorites Watch
View GJK's profile
GJK
27 posts in 1352 days
06-06-2016 08:15 PM
Topic tags/keywords: teach lersson band saw
Moving into band saw work and have read a few photo books on it but would like a “private class” with an experienced woodworker in my workshop in Cleveland Park (near Zoo & Uptown Theater) in Washington, DC on my new Jet 14” band saw. The lesson would be my first use of the machine, so
-Equipment check to ensure all is ready to go;
-Safety procedures
-Use of fences;
-Changing & tightening blade;
etc.
I understand a private session at $75 / hour might be more than fair.
Anyone care to do it who lives close by and knows this equipment:
Motor: 3 HP, 1 Ph, 230 V, 15/7.5 Amps
13-1/2” of resaw capacity
Cutting capacity width (In.): 13-1/2
Cutting capacity height (In.): 13-1/2
Blade length (In.): 125
Blade speed (SFPM): 3000
Table size (L x W) (In.): 21-1/2×16
Blade width (In.): 1/2
Redesigned fence with laser etched scale and micro-adjust feature
Two-position faceplate provides appropriate support for every cut
Tool-less guide adjustments
Conveniently located dual dust collection ports
Sturdy wheels feature a shallow crown and polyurethane tires
Heavy duty tensioning with quick release
Four sided blade guard
Blades can be removed out the front of the table, no bending or angling required
Round table insert features leveling screws for precise adjustment
Stock Number: 714550
Maximum saw blade width (In.): 3/4
Minimum saw blade width (In.): 1/8
Table tilt (Deg.): 45 right/10 Left
Table height from floor (In.): 39
Dust collection minimum CFM required (CFM): 400
Dust port outside diameter (In.): 4
Weight (lbs): 360
No assembly required
1/2”, 4 TPI Hook blade included
-- Gary, Washington, DC
1 reply so far
View AandCstyle's profile
AandCstyle
3027 posts in 2222 days
#1 posted 06-06-2016 10:26 PM
Gary, you might be able to get some assistance by contacting the Washington Woodworkers Guild. HTH
-- Art
