dedicated cheaper drill/router bits for plywood?
Forum topic by treesner posted 06-06-2016 06:03 PM 537 views 0 times favorited 2 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 1165 days
06-06-2016 06:03 PM
Topic tags/keywords: plywood bits
As i look into investing in quality drill bits and router bits I was wondering if anyone has two sets of bits, one expensive set for hardwood and one cheaper set for plywood?
It seems like plywood is hard on edges with all the glue involved which is why i was thinking you might want a cheaper set of bits that could be replaced easier after the wear and tear of the plywood
I have plywood specific blades but that’s because the need for high TPI to not splinter the top veneer layer
2 replies so far
View bondogaposis's profile
bondogaposis
5090 posts in 2552 days
#1 posted 06-06-2016 06:12 PM
Nah, too complicated.
-- Bondo Gaposis
View William Shelley's profile
William Shelley
595 posts in 1670 days
#2 posted 06-06-2016 07:47 PM
The only thing that I might do would be to use a dedicated router bit or table saw blade if I was working with MDF extensively for a project. MDF will dull even carbide pretty fast.
-- Woodworking from an engineer's perspective
