Pantograph for inlay work
Forum topic by difalkner posted 06-06-2016 01:15 PM 1000 views 1 time favorited 11 replies Add to Favorites Watch
View difalkner's profile
difalkner
122 posts in 2102 days
06-06-2016 01:15 PM
A few weeks ago I finished the pantograph I designed for doing inlay work on guitars. This was initially for use with my Dremel and flex cable. I did one simple test with it and that worked fine but I’ll do some more before I cut into some nice exotic wood or Abalone. Since I built and posted the video I have modified the pantograph to mount my Dremel directly because I discovered the flex cable chuck runout was too great to do accurate work. Also, I have added a micro-adjustment to the stylus since the video.
It’s very smooth and precise so I’m pleased with that part of it. It will do 2:1, 3:1, and 4:1 reductions.
My target testing piece is in the upper right hand corner of the video -
Enjoy!
David
-- Nothing to do with woodworking at all, just our music at church (I'm the guy with the Koa Takamine) - https://www.youtube.com/channel/UCSpLecPAn4AJEp6qHC7C44A
11 replies so far
View Redoak49's profile
Redoak49
3663 posts in 2188 days
#1 posted 06-06-2016 01:24 PM
Very nice….a really good build
difalkner
#2 posted 06-06-2016 10:04 PM
Thanks! It was kind of fun doing this one.
View custer's profile
custer
1 post in 1006 days
#3 posted 07-01-2016 05:33 PM
This is one of the best (if not the best) pantograph builds I’ve seen. Thank you for sharing.
difalkner
#4 posted 07-02-2016 05:03 PM
This is one of the best (if not the best) pantograph builds I ve seen. Thank you for sharing.
- custer
Thanks so much, Custer!
View Woodknack's profile
Woodknack
12430 posts in 2580 days
#5 posted 07-02-2016 05:23 PM
Smart looking machine. Well done.
TopamaxSurvivor
18390 posts in 3876 days
#6 posted 07-03-2016 03:13 AM
Nice job!
View oldnovice's profile
oldnovice
7328 posts in 3568 days
#7 posted 07-03-2016 06:06 AM
difalkner, really nice addition for your work!
I remember seeing a machine like this in the model shop where I used to work a few decades ago.
I assume that these have all been replaced by CNC like machines.
I see you discovered the run out of the Dremel flex shafts too.
I wrote to Dremel about it but never got a response.
difalkner
#8 posted 07-03-2016 12:43 PM
- oldnovice
Thanks! Yeah, I have had this Dremel for about 20 years and never used the flex shaft, so I was a bit surprised it had so much runout. I modified the pantograph to accept the Dremel directly but it also has a bit of runout. Right now I don’t need a new Dremel but I’m wondering if a new one has less runout than my old one.
oldnovice
#9 posted 07-03-2016 09:52 PM
difalkner, I was/am really dissapointed with the Dremel!
Have you checked into of the Foredom
I see a lot of carvers use these but I don’t know anything about run out but the model above will do 18,000 RPM.
I wonder if these flextools could be adapted to other motors?
difalkner
#10 posted 07-04-2016 02:06 AM
I see a lot of carvers use these but I don t know anything about run out but the model above will do 18,000 RPM.
- oldnovice
I am familiar with Foredom but have never used one. It has to be better than the Dremel. If it turns out I need this pantograph often then I may look into getting a Foredom.
oldnovice
#11 posted 07-04-2016 05:28 PM
difalkner, do a search for Foredom on this site and you will see reviews and that there are many who use this tool..
