Piano Hinge Use
Forum topic by DonJ posted 04-18-2010 03:31 AM 1740 views 0 times favorited 3 replies Add to Favorites Watch
View DonJ's profile
DonJ
251 posts in 3644 days
04-18-2010 03:31 AM
I’m building one of the 3’ tall jewlery chests with the sides that swing open. The plans call for piano hinges for both side sections and the top. For those that have used the piano hinges for this application, what is the best method of installing the hinges? Do you install them like a traditional hinge and mortise the edges? Thanks, as always.
-- Don, San Antonio, TX
3 replies so far
View SnowyRiver's profile
SnowyRiver
51457 posts in 3597 days
#1 posted 04-18-2010 04:28 AM
I have a couple of cabinets like the ones you are making in my gallery. I just attached the hinges to the back of the sides and to the bottom of the top and it looks and works fine.
-- Wayne - Plymouth MN
View John Gray's profile
John Gray
2370 posts in 4002 days
#2 posted 04-19-2010 07:03 PM
I’ve made several items with Piano Hinges and just surface mounted them and they look and work fine.
View TheDane's profile
TheDane
5515 posts in 3780 days
#3 posted 04-19-2010 09:40 PM
I did a bench with a storage compartment under the seat a few years ago where I mortised in a piano hinge. I did that so the seat was flush with the supporting framework and take the weight off the hinge.
