Grizzly G0555 question
Forum topic by Tom posted 06-05-2016 09:08 PM 733 views 0 times favorited 7 replies Add to Favorites Watch
View Tom's profile
Tom
175 posts in 1112 days
06-05-2016 09:08 PM
I recently received/set up my G0555 bandsaw. One thing I’m having problems with (other than learning to use it) is the fence doesn’t lock in to place and I can’f figure out how to adjust it so that it will. The lever won’t go all the way down and the locking mechanism seems to need a 1/4” more clearance to lock down. I’ve contacted tech support…but their response wasn’t that helpful. Anyone have this saw/same issue and how did you fix it?
7 replies so far
View FancyShoes's profile
FancyShoes
550 posts in 1416 days
#1 posted 06-07-2016 09:55 PM
Is there a screw adjustment on the lever at all? Get slme pics posted, that might give us some idea on how to help. Or you may have to take it back and get a new one.
View Lazyman's profile
Lazyman
2163 posts in 1439 days
#2 posted 06-07-2016 10:17 PM
Grizzly puts a couple of different fences on their line of bandsaws. Does yours have the one with a square rail or the one that looks sort of rounded? Mine has the rounded rail and I don’t see any adjustment either. if yours has the rounded one, is it possible that it is missing the little strip of metal between the cam and the rail?
View Tom's profile
Tom
#3 posted 06-07-2016 11:14 PM
I figured it out. Found where to adjust the fence.
View Tammy69's profile
Tammy69
2 posts in 500 days
#4 posted 03-05-2017 01:01 AM
How did you adjust it?
View TheFridge's profile (online now)
TheFridge
9708 posts in 1538 days
#5 posted 03-05-2017 02:57 AM
2 set screw behind the 2 wear pads probably?
View Tom's profile
Tom
#6 posted 03-05-2017 02:58 AM
When you close the handle it only goes down a little; there’s a screw that lets it tighten inside so it won’t move.
Tammy69
2 posts in 500 days
#7 posted 03-05-2017 01:58 PM
There is no set screws. There’s only 1 wear pad. And, the other answer really makes no sense. At least to me. Anyone else have this issue with the fence on the Grizzly Bandsaw G0555?
