Whirligig Design
Forum topic by woodify posted 06-05-2016 02:48 PM 928 views 0 times favorited 5 replies Add to Favorites Watch
View woodify's profile
woodify
292 posts in 2040 days
06-05-2016 02:48 PM
Topic tags/keywords: question
I’m looking for some design ideas for a propeller that can be mounted on top of the whirligig. I’ve searched around the internet but I’m not finding anything.
I started building a whirligig and I ran into an issue with my propeller design. I used a two blade propeller design (like you’d find on an airplane) however I mounted it on top of the whirligig instead of on the side. I now realize that the propeller needs to be perpendicular to the wind direction else it doesn’t work.
I’d like to keep the propeller on top of the whirligig any design suggestions?
Thanks
-- Woodify ~~ https://www.youtube.com/woodified?sub_confirmation=1
5 replies so far
View Woodknack's profile
Woodknack
11485 posts in 2348 days
#1 posted 06-05-2016 05:51 PM
Edit, I read your post again and think I misunderstood, you are making a helicopter like whirligig?
View oldnovice's profile
oldnovice
6773 posts in 3335 days
#2 posted 06-05-2016 07:45 PM
If you want to drive something with the prop you might want to try paddles perpendicular to the wind as normal props are parallel to the wind.
View littlecope's profile
littlecope
3071 posts in 3470 days
#3 posted 06-06-2016 12:31 AM
In order to use the wind as a power transfer,
you’re going to have to think of using the Propeller more like a “Pinwheel”...
And unless you use very large blades,
four (or more) Blades will ‘catch’ more Wind (more surface area)...
If you want a a “Helicopter style”, horizontal prop,
wind speed measuring devices are frequently made that way,
but with some sort of “cup’ on the ends of the blades…
Good Luck!
oldnovice
#4 posted 06-06-2016 04:55 AM
Do a Google Search for anemometer and you will see what Mike described above.
The more “cups” the more power so make sure you have good bearings/support!
I made one, a long time ago, with L’eggs egg shaped product packaging but I don’t know if they still package them that way or if you have a significant other that wears panty hose and could be a source for these packages!
woodify
#5 posted 06-06-2016 09:13 PM
I now have multiple ways forward. Thank you for the suggestions.
