Grizzly G0771 passes the nickel test
Forum topic by jacobem3 posted 06-05-2016 02:02 AM 662 views 0 times favorited 5 replies Add to Favorites Watch
View jacobem3's profile
jacobem3
30 posts in 1362 days
06-05-2016 02:02 AM
With the stock blade and a Harbor Freight mobile base.
https://www.youtube.com/watch?v=Genao7zMsU8
This is my first table saw and I’m pretty happy so far. The fence locks up square and moves much smoother than I expected with aluminum rails. I can push it with one finger and it slides 3/4 of the way to the other end of the table.
5 replies so far
View AlaskaGuy's profile
AlaskaGuy
3914 posts in 2218 days
#1 posted 06-05-2016 02:30 AM
Congrats on your new saw. Do you always cut at that rate of feed?
View knotscott's profile
knotscott
7877 posts in 3284 days
#2 posted 06-05-2016 03:05 AM
Now add that 6 cents to another $30 and get your new saw a suitable blade!
jacobem3
#3 posted 06-05-2016 03:27 AM
Thanks! That’s the speed I’ve been going. There’s a lot of resistance when I push wood through and some vibration when I go faster, I’m hoping better blades will be smoother and easier to feed. The arbor has no measurable run out, the blade is aligned to the slots within 0.001” and the fence is almost parallel, opening up 0.004” at the far end but it’s a bit concave dipping to 0.012” in the middle. I’ve got a Freud ultimate plywood blade and a Freud rip blade coming in the mail.
View kowwpokey's profile
kowwpokey
1 post in 631 days
#4 posted 06-05-2016 04:45 AM
I have the same saw and had the same issue with resistance until I calibrated the table to the blade and now it cuts beautifully with no resistance.
-- I've cut this board three times and it's still too short...
View conifur's profile
conifur
955 posts in 1060 days
#5 posted 06-05-2016 04:55 AM
Now get this blade and look at the report on it.
http://www.amazon.com/Freud-LU87R010-10-Inch-24-Tooth-PermaShield/dp/B0000225UH/ref=sr_1_1?ie=UTF8&qid=1465102440&sr=8-1&keywords=freud+blade+10+inch
