Slip/loose tenons
« back to Joinery forum
Forum topic by revanson11 posted 06-03-2016 06:14 PM 573 views 0 times favorited 2 replies Add to Favorites Watch
View revanson11's profile
104 posts in 2263 days
06-03-2016 06:14 PM
Topic tags/keywords: tenon slip loose joinery joining
Okay, this is going to sound really dumb to some of you but I have a question concerning tenons. I am familiar with mortise and tenon joinery but I am a little confused with what is called slip or loose tenons. I am working on a project that calls for slip tenons and I am a little confused about gluing them. If it is called a slip/loose tenon are they still supposed to be glued in place? If so why would it be called loose/slip? Thanks for any clarity on this issue.
-- Randy, Central MN
2 replies so far
View bondogaposis's profile
4630 posts in 2281 days
#1 posted 06-03-2016 06:24 PM
First they are not called “loose tenons” because they are loose, they should fit snug like any other tenon. The reason for them being called loose is that there are 2 mortises and the tenon is a separate piece of wood attached to both mortises by glue. Clear as the plot in a Faulkner novel?
-- Bondo Gaposis
View endgrainy's profile
251 posts in 1818 days
#2 posted 06-04-2016 12:32 AM
A slip or loose tenon is just a tenon that was not originally part of the workpiece, as opposed to an integral tenon. Yes, the loose tenon should be glued into place in the mortises on each workpiece of the joint. A Festool Domino is an example of a loose tenon.
-- Follow me on Instagram @endgrainy
