Building carbide tool help
« back to Woodturning forum
Forum topic by loiblb posted 06-03-2016 03:16 PM 999 views 0 times favorited 18 replies Add to Favorites Watch
View loiblb's profile
loiblb
142 posts in 1085 days
06-03-2016 03:16 PM
For those that have built some of these. I ordered some carbide bits from Captain Eddy. I would like to get ideas on where to get the metal rods. Also how long to make the rod in front of the handle.
Your thoughts on is round rod or square best?
Thanks
18 replies so far
View Ger21's profile
Ger21
1075 posts in 3160 days
#1 posted 06-03-2016 03:20 PM
Ebay will be your cheapest source for steel rods.
McMaster-Carr is another good option, but will cost more.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View Woodknack's profile (online now)
Woodknack
11831 posts in 2409 days
#2 posted 06-03-2016 03:43 PM
Square for the rods. Round rods will try to spin and cause a catch. You can use round for round cutters if you like.
View TheDane's profile
TheDane
5448 posts in 3692 days
#3 posted 06-03-2016 04:40 PM
Ditto on square stock. I bought low-carbon steel bar stock at my local big box (Menards).
View jtriggs's profile
jtriggs
181 posts in 3846 days
#4 posted 06-03-2016 06:36 PM
I have a local trailer manufacturer that sold me 1/2” bar stock really cheap. 3 feet for less than 4 bucks. I made mine about 8-9 inches beyond the handle and 3-4” 8 inside the handle. They turned out great. See my projects to view.
-- Jon --Always remember, never live your life by a motto.
View OSU55's profile
OSU55
1705 posts in 2019 days
#5 posted 06-03-2016 09:23 PM
Here is my project for the tools I made with measurement details. While mine are square rods, I’m not so sure round wouldn’t be better. I find I tilt the cutter quite often for more of a shearing cut, reducing tear out. I don’t use mine much anymore. After I learned how to really use a bowl gouge, I found I preferred a gouge to the carbide. Never did get to like the carbide over HSS for spindle work.
View LeeMills's profile
LeeMills
551 posts in 1330 days
#6 posted 06-03-2016 09:33 PM
Most real hardware stores sell “key stock”. It may also be available at the hardware boutiques such as Lowes or Home Depot.
View Bill7255's profile
Bill7255
427 posts in 2314 days
#7 posted 06-04-2016 09:32 AM
- LeeMills
I used key stock, I found it at tractor supply. 1/2” X 12” was about $5.00
-- Bill R
View marcsitkin's profile
marcsitkin
28 posts in 786 days
#8 posted 06-04-2016 01:35 PM
I went to a local steel supply and fabrication shop and got 3 cutoffs around 24” in length for $5. They came with some sort of primer on them that was very hard to remove. Took an hour between wire wheels and sanding.
I’m going to build two more tools, any thoughts on removing the paint faster?
Sorry to hijack this thread a bit, but if you can get steel without this primer, do so and save some time.
-- Thanks, Marc Sitkin, Harwich, MA
View Nubsnstubs's profile
Nubsnstubs
1300 posts in 1759 days
#9 posted 06-04-2016 02:14 PM
I m going to build two more tools, any thoughts on removing the paint faster?
- marcsitkin
That could have been a zinc plating instead of paint…...... Jerry (in Tucson)
marcsitkin
#10 posted 06-04-2016 04:06 PM
- marcsitkin
- Nubsnstubs
Thanks Jerry, maybe a plating, but shows no crystal structure. I’m going to put in an electrolytic bath that I use for rust removal and see if it removes the coating. It’s really on there!
View JoeinGa's profile
JoeinGa
7736 posts in 2036 days
#11 posted 06-04-2016 06:12 PM
I’ve been using some 5/8” aluminum barstock for mine. You can see here. (and if you move forward on my blogs you can see the changes I made in handles as I made more.
http://lumberjocks.com/JoeinGa/blog/54554
marcsitkin
#12 posted 06-04-2016 08:27 PM
I ve been using some 5/8” aluminum barstock for mine. You can see here. (and if you move forward on my blogs you can see the changes I made in handles as I made more.
- JoeinGa
Hi Joe-
I took a look at your blog and the tools look nice. How do you like using them compared to carbide tipped steel bar? They must be quite a bit lighter.
View Jack Lewis's profile
Jack Lewis
276 posts in 1107 days
#13 posted 06-04-2016 10:46 PM
You should try the shear round cutters. The difference is comparable to gouge.
http://azcarbide.com/product/12mm-round-shear-insert-fits-hunter-4-tool/
Thanks
- loiblb
-- "PLUMBER'S BUTT! Get over it, everybody has one"
loiblb
#14 posted 06-06-2016 12:45 AM
There are some great looking tools shown here.
Is there a advantage using aluminum bar stock over steel bar stock?
I see my tool rest has marks from steel turning tools.
TheDane
#15 posted 06-06-2016 02:11 AM
Best way I have found to avoid that is to round the edges of tool shafts so they don’t dig into the tool rest.
