| Forum topic by Bart70 | posted 1129 days ago | 844 views | 0 times favorited | 11 replies | ![]() |
1129 days ago |
Topic tags/keywords: question I would like to build some simple chairs, I would like to have the “butt” indentation that most wooden chairs have but I have no idea how it’s done. I have searched the net but can’t even think of key words to use in the search. Any help would be appreciated. Also I would like a method that is consistently repeatable so all the chairs are the same. Thanks. -- Got Wood? |
11 replies so far
#1 posted 1129 days ago |
Hi Bart, I googled ” wood chair seat profile” and found this link to FineWoodworking.com You may have to sign up for a 14 day free trial to view this article but the answer you want is there. I hope this helps, -- Kenny... The man who needs a tool he doesn't have is already paying for it. |
#2 posted 1129 days ago |
I’ll check it out, thanks Kenny. -- Got Wood? |
#3 posted 1129 days ago |
That would be a magic template to find..Let us know .. -- Bueno...Nacho.. |
#4 posted 1129 days ago |
If your near a major libary, Micheal Dunbar’s book on ” Winsor Chairs ” has a full chapter on making chair seats. -- Tom D |
#5 posted 1129 days ago |
I like to make a mock up out of mdf, pine, poplar, something cheap. Sit in it for a while. Angle grinders make short work out of sculpted seats like that. Reproducing them X 6 may be the problem. Lots of practice. -- Michael Murphy, Woodland, CA. |
#6 posted 1129 days ago |
Repeatable is the crux here. I have always done it the hand tool way with a combination of an adze, gouge, and travisher. This works quickly and creates a great finish. It is repeatable by using a template to define the outer edges and a depth gauge to establish the maximum depression then you blend the curve. I suppose the same could be done with a series of router bits and a wide trammel base plate but I don’t think you could get the same organic curve without changing out bits many times and a lot of sanding to blend the curve. -- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com |
#7 posted 1129 days ago |
Sculpting a chair seat: http://thecraftsmanspath.com/2009/03/30/sculpted-rocking-chair-shaping-the-seat/ |
#8 posted 1129 days ago |
Here’s a link to a youtube video .. http://www.youtube.com/watch?v=aiS_NKorXYk He uses a grinder and a spoon shave i think. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#9 posted 1129 days ago |
When I have several chairs (or two) that have to match, I draw the outline and make a series of concentric lines 1” apart. Then from actual center of seat, draw lines radially (about eight, give or take) and then chuck a 1/2” bit into the drill and set the depth at all intersecting points. I just use a stop collar for the varying depths. From there it’s a matter of grinding away to blend the bottoms. Keep in mind the ridge line in the center. The depths can be worked out ahead of time from a pattern. |
#10 posted 1128 days ago |
How about a router and a pendulum jig. Or if you need the two leg indents also, you can just build two different jigs for the different profile curves. Can’t remember where I saw it, but I’m sure it was on here somewhere… -- Childress Woodworks |
#11 posted 1128 days ago |
cheat http://charlesneilwoodworking.com/category_player.php?type=1&cat=1&video=chairseat.flv the chain saw products are quite agressive , I suggest use the grinders , as well you can find the 4” disc sanders ( like a flap sander), at the local hardware they are used for smoothing welding, the dado thing , is all too fast and slick just be careful |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1525 |
3542 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
