Elu Power Feeder
Forum topic by TheAmateur posted 04-16-2010 01:32 AM 3716 views 0 times favorited 4 replies Add to Favorites Watch
View TheAmateur's profile
TheAmateur
4 posts in 3064 days
04-16-2010 01:32 AM
Topic tags/keywords: question
I need some help from the old tool restorers out there. I am trying to find a belt for a Elu International Power Feeder MVA 34. The original part number is 34 26 01 00 but I have no Idea where to begin looking. I also have a part number 199240-00 but have no idea where the owner got this part number. He just told me that was what he bought several years ago but lost those belts when he moved his shop. Any ideas or suggestions??
View Charles Wilson's profile
Charles Wilson
18 posts in 3855 days
#1 posted 04-16-2010 04:16 AM
I’m not 100% sure about your feeder configuration, Is it the type with the motor mounted horizontally in line with the feed direction or the more traditional type with the motor mounted vertically?
If you are looking for the drive belt from the motor to the feeder gearbox, a good belt /power transmission supply house should be able to find one for you just by the specs and size (of course a sample would help a lot).
Maybe one on the older woodworking machinery dealers in your area might still have a parts guy that will know what you need. J & G machinery comes to mind.(http://www.jgmachinery.com/)
Now if your feeder uses a tractor type feed belt set instead of rollers, Western Roller is the place to call.
good luck
Charles
View bill merritt's profile
bill merritt
203 posts in 3374 days
#2 posted 04-16-2010 07:33 AM
Do you or anyone know where to get work done on a great router? Made by Elu,can’t find parts. Sorry about butting in.
-- Bill Merritt -Augusta Ga. woodworker
View davidpettinger's profile
davidpettinger
661 posts in 3285 days
#3 posted 04-16-2010 03:48 PM
This is for the Amateur, you might find help here, I believe your unit was last made in 1989 and there is only partial support, you might get some help by contacting these guys.
http://service.dewalt.co.uk/Products/SearchResults.aspx?Type=Products&Filter=MVA34&CNType=
An e-mail to them could not hurt.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View danny_buie's profile
danny_buie
1 post in 2538 days
#4 posted 09-07-2011 04:35 AM
I found this post while I was looking for information on an Elu feeder. I have a feeder I believe to be an Elu MVA 34 based on the others I have seen on the net. I am looking for documentation. Mine does have a new belt with the following data..
Goodyear Variable Speed Belt Part Number: 1430V215
14 = 14/16” (7/8”) wide
30 = 30 degree Groove angle
215 = 21.5 pitch length
I had trouble getting the varable speed (Reeves Drive) to function properly. I got it working in VS by manually opening the motor sheave and tightening down on the driven sheave and then replacing the cover. Change the speed with the feeder running.
Maybe this will help someone in the future.
