Mortising Chisels
Forum topic by Tom S. posted 04-15-2010 10:24 PM 1328 views 0 times favorited 6 replies Add to Favorites Watch
View Tom S.'s profile
Tom S.
29 posts in 3182 days
04-15-2010 10:24 PM
Topic tags/keywords: chisel
I am looking to purchase some good quality hand mortising chisels. I have noticed that you pay for quality and I don’t have a problem with that. What sizes would be good to start with if I was to purchase just a couple to begin with? What brands would you recommend as well.
-- Sunrunner34
View bigike's profile
4053 posts in 3219 days
#1 posted 04-15-2010 10:29 PM
I would go with either ones to match mortices you often do or just go with 1/8-1/2” mortices arent to big unless your doing a workbench or something like that.
-- Ike, Big Daddies Woodshop,
View Wintersedge's profile
83 posts in 2905 days
#2 posted 04-15-2010 11:01 PM
You can never go wrong with Lie Nielsen, but they are pretty pricy.
-- Motivation alone is not enough. If you have an idiot and you motivate him, now you have a motivated idiot.
View rwyoung's profile
409 posts in 3403 days
#3 posted 04-15-2010 11:47 PM
I picked up the Narex 3-piece set. While they are technically metric sizes, that doesn’t matter if you always set up your gauges to the chisel. A decent value and so far they have worked fine. However I don’t have a lot of time behind the mallet with them.
The LN chisels are definitely nice. As an option, you could just purchase them one at a time as needed.
The used market has plenty of old Buck-Brothers, Isles and OVBs hanging around if you don’t mind a little rehabilitation work.
-- Don't sweat the petty things and don't pet the sweaty things.
View rtb's profile
1101 posts in 3644 days
#4 posted 04-16-2010 12:58 AM
For the price I don’t think you can beat the narex for mortise or bench chisels and you might just find out that they have as much quality aas you might ever want.
-- RTB. stray animals are just looking for love
View barryvabeach's profile
159 posts in 2975 days
#5 posted 04-16-2010 01:27 PM
Tom, I strongly suggest you buy a 1/4 inch Ray Ises mortising chisel. It is expensive, but well worth it. It is one of the rare tools that lives up to the hype. You could also buy a 5/16 if you work alot with 5/4 stock, but 1/4 should handle most everything you need. You can find the Ray Isles at toolsforworkingwood.
I know the price may put you off at first, but do a google search on ray ilse mortise chisel and I doubt you will find someone that says anything negative about it .
View Eric_S's profile
1565 posts in 3126 days
#6 posted 04-16-2010 02:05 PM
I have Sorby 3/8” chisel that I found to be the one I use most. I haven’t needed any other mortise chisels yet, but a 3/4” and 1/4” bench chisel help too to clean up edges if drilled or routed out first
-- - Eric Noblesville, IN
