Praise for Whiteside router bits
Forum topic by CharlesA posted 06-02-2016 02:14 PM 723 views 0 times favorited 10 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3329 posts in 1825 days
06-02-2016 02:14 PM
I always lean toward the cheapest workable solution. Almost all my tools are CL finds, for instance. I didn’t go bottom of the barrel for most of my router bits, but I didn’t spend a ton either. In the last three months I have purchased 3 Whiteside bits, straight 1/4” and 3/8” and a rabbeting bit set. I had purchased a cheap (in every way) rabbeting set because I didn’t think I’d use it much. Instead, the cheap rabbeting bit chewed up the frames I was working on.
I am stunned at how clean all three of these bits cut. I will buy Whiteside bits going forward.
10 replies so far
View Handtooler's profile
Handtooler
1579 posts in 2160 days
#1 posted 06-02-2016 02:35 PM
I certainly agree with your decision. I have purchased and use the Whiteside bits. I have a 6 piece set of 1/2” shaft and 5 single 1/4” shaft speciality bits. All cut super and are somewhat cheaper than other Freud bits I also own.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Greg the Cajun Wood Artist's profile
433 posts in 970 days
#2 posted 06-02-2016 02:39 PM
I feel that Whiteside bits are the best available. I have been using them for about 10 years now and have replaced any other worn bits from other brands with Whiteside. Quality always is the best value in the long run.
-- Wood for projects is like a good Fart..."better when you cut it yourself"
View BurlyBob's profile
BurlyBob
5556 posts in 2293 days
#3 posted 06-02-2016 02:42 PM
I’ve only buy Whiteside router bits. They’ve proven to be the best and most economical over the long haul. Buy the best and it will last you a lifetime, buy the cheapest and buy it a 2nd, 3rd and 4th time!
A no brainer from my perspective.
View jdmaher's profile
jdmaher
430 posts in 2607 days
#4 posted 06-02-2016 03:14 PM
Whiteside is my favorite, whenever they make what I need, and I’ve been using them at least 20 years. I have yet to have a problem with any of them. They just always work really well.
-- Jim Maher, Illinois
View bonesbr549's profile
bonesbr549
1558 posts in 3095 days
#5 posted 06-02-2016 03:20 PM
White side is my first go to bits have been just well made.
View bruc101's profile
bruc101
1200 posts in 3570 days
#6 posted 06-02-2016 03:21 PM
We’ve been using Whiteside soild surfacing bits to do most all of our soild surface countertops with since the 90’s and have never had a failure with one.
-- Bruce Free Plans http://plans.sawmillvalley.org
View RogerM's profile
RogerM
792 posts in 2427 days
#7 posted 06-02-2016 04:35 PM
I have had nothing but excellent results from the Whiteside bits I have used/
-- Roger M, Aiken, SC
View knotscott's profile
knotscott
8057 posts in 3403 days
#8 posted 06-02-2016 06:00 PM
Never been less than totally happy with my WS bits.
View JAAune's profile
JAAune
1802 posts in 2345 days
#9 posted 06-03-2016 05:14 AM
For most hobbyists, a good router bit will last a lifetime so long as they aren’t run hot. Carbide breaks down with heat.
I use Whiteside for router tables and handheld use but Vortex for the CNC.
View Wondermutt's profile
Wondermutt
69 posts in 884 days
#10 posted 06-03-2016 01:27 PM
After recommendations here, I started using ws bits. Could not be happier. A definite upgrade for me.
