New bandsaw...table is icky
Forum topic by Tom posted 06-02-2016 01:29 AM 994 views 0 times favorited 14 replies Add to Favorites Watch
View Tom's profile
Tom
178 posts in 1296 days
06-02-2016 01:29 AM
I finally got my new Grizzly bandsaw setup and the table is..well covered in some sort of grease. What’s the best way to clean it off? I’ve seen 409 (don’t have any) as a suggestion along with mineral spirits (I have this.) I don’t want to mess it up but also want it clean so I can wax it.
14 replies so far
View JayT's profile
JayT
6008 posts in 2447 days
#1 posted 06-02-2016 01:32 AM
I scrape off all I can with a razor blade scraper and then use WD-40 to clean off the rest. It dissolves the shipping grease/cosmoline pretty well without hurting any finish. I would think mineral spirits or any similar solvent would work, as well.
-- In theory, there is no difference between theory and practice. In practice, there is.
View WhyMe's profile
WhyMe
1080 posts in 1797 days
#2 posted 06-02-2016 01:36 AM
Mineral spirits is fine to clean off grease.
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#3 posted 06-02-2016 01:39 AM
Did you look at the manual where it tells you how to do it?!? :)
They suggest WD-40, but MS works better.
View Tom's profile
Tom
#4 posted 06-02-2016 01:57 AM
Brad: I read the parts on assembly and adjusting the blade just to get it running and for a quick test cut. I hadn’t gone through all of the manual yet and I still have to get the guide bearings adjusted just right. They were good enough to chop up some scrap 2×4 pieces into smaller pieces (with curved cuts.) I’m not sure if the fence is right..it doesn’t “lock” and I’ve emailed Grizzly on that.
MrUnix
#5 posted 06-02-2016 02:11 AM
View JBrow's profile
JBrow
1366 posts in 1156 days
#6 posted 06-02-2016 03:48 AM
Tom,
Some time ago I purchased a can of Sprayway’s 909 Industrial Heavy Duty Orange Plus (from Grizzly) to remove the protective film typically applied to cast iron. I works very well and one can will last a lifetime. While it may or may not work better than WD40 or Mineral Spirits, it does smell good – the smell of oranges wafting through the shop.
View AZWoody's profile
AZWoody
1419 posts in 1460 days
#7 posted 06-02-2016 04:04 AM
I’ve found MEK does the best when I have to clean that grease off tools. I used to use Mineral Spirits but that takes a lot more scrubbing and repeated applications.
View RandyinFlorida's profile
RandyinFlorida
257 posts in 2303 days
#8 posted 06-02-2016 12:38 PM
and yes wax is a good thing.
-- Randy in Crestview Florida, Wood Rocks!
View Woodbum's profile
Woodbum
846 posts in 3301 days
#9 posted 06-02-2016 08:11 PM
The table is “icky”? Well, we don’t need that! A plastic taping knife, mineral spirits and a bunch of paper towels plus a little of your time is all that is needed to de-”ickyfy”your new bandsaw table. Brad was right on the mark with his comments. Clean it up and put on some Boeshield and you will be right as rain. Without the cosmoline, your new bandsaw table might have REALLY been “icky” with rust from the ocean trip; and you would have been more unhappy. See, there is a bright side to everything.
-- "Now I'm just another old guy wearing funny clothes"
View Tom's profile
Tom
#10 posted 06-02-2016 08:36 PM
I’ve de-ickyfied the table and put a coat of wax on it; it’s nice and clean. Now to adjust the fence so it’s straight and fits correctly and get the blade guide set up. That part of the book I’ve read…but found a video a bit clearer on how to set things up.
I do know to keep my fingers away from the moving sharp metal bits and to use push sticks. I type a LOT for my job and need all my fingers.
View dabob's profile
dabob
8 posts in 3460 days
#11 posted 06-02-2016 08:41 PM
I ve found MEK does the best when I have to clean that grease off tools. I used to use Mineral Spirits but that takes a lot more scrubbing and repeated applications.
- AZWoody
AZWoody .. . MEK does amazing stuff . . . but because its so good the EPA takes a dim view of it . . . it is some really nasty stuff – so if you 1. can get it. 2. Use it very carefully, and btw it burns as good as pure alcohol does.
-- The person who says it cannot be done should not interrupt the person doing it. . . .
View MacNut11's profile
MacNut11
32 posts in 2272 days
#12 posted 06-03-2016 05:38 PM
It’s called cosmoline(spelling?). I once had to remove it from a milling machine table that was 112” x 50” with I think six 3/4” t-slots. That was a job and a mess. Used cleaning fluid from a parts washing vat.
AZWoody
#13 posted 06-03-2016 05:42 PM
- AZWoody
- dabob
I didn’t know it was hard to get, the local Lowes has it here, but maybe it’s a state by state thing?
View upinflames's profile
upinflames
217 posts in 2398 days
#14 posted 06-03-2016 07:47 PM
Naphtha…..it’s been around a long time, it’s not just for thinning paint….. Many of the old timer auto shops have used it for years as a parts cleaner. It really is a multi purpose cleaner. If you live in Kalirussia (california) you may be SOL, but coleman stove fuel is the same stuff, a little more pricy though.
