I am looking for VERY basic birdhouse plans
« back to Coffee Lounge forum
Forum topic by backyarder1 posted 04-15-2010 05:38 PM 5760 views 0 times favorited 10 replies Add to Favorites Watch
View backyarder1's profile
backyarder1
38 posts in 3636 days
04-15-2010 05:38 PM
Hi gang. I am looking for a very basic cutting diagram for a simple bird house with a peak roof. Does anyone have plans or do you know where I can find some?
Thanks
10 replies so far
View Rustic's profile
Rustic
3253 posts in 3465 days
#1 posted 04-15-2010 05:49 PM
just google free birdhouse plans
View lumberdustjohn's profile
lumberdustjohn
1263 posts in 3035 days
#2 posted 04-15-2010 05:52 PM
backyarder1
#3 posted 04-15-2010 05:56 PM
Well, obviously I started by googling free birdhouse plans. I got 863,000 hits. I was trying to limit my results.
backyarder1
#4 posted 04-15-2010 05:59 PM
Thanks lumberdustjohn
lumberdustjohn
#5 posted 04-15-2010 05:59 PM
Enjoy your build.
-- Safety first because someone needs you.
View Brad Hancock's profile
Brad Hancock
30 posts in 3110 days
#6 posted 04-15-2010 06:10 PM
I don’t have a diagram, but I just built several that were very easy.
Using a 1×6, which is actually 5.5 inches wide, measure up 5.5 inches from the bottom and cut a 45 degree angle from both sides, so the cuts meet in the center of the board, 8.25 inches from the end. You’ll now have the front/back of the house. Repeat to get the other end. (You can use the “scrap” triangles left over to glue up additional houses it you want to.)
For a small house, cut two pieces for the sides that are 4×5.25 inches (leaves a small gap at the top for ventilations.) For a larger house, cut two sides that are 7×5.25 inches. The smaller sides fit inside the front/back and are glued/nailed in place. The larger sides are glued/nailed outside the front/back.
Drill a hole between 1 to 1.5 inches in diameter in the front for the entrance. Contrary to popular opinion, birds do not need or want a perch outside the house. The hole is sufficient.
Glue/nail everything together.
Cut a bottom that fits inside the house. Should be 4×4 for the small house or 5.5×5.5 for the larger one. Glue/nail in place. I like to drill small holes (1/4 inch) in the corners of the floor to allow drainage.
The roof consists of two pieces, one 4.75×7, the other 5.5×7. These are glued/nailed together to form a ninety degree angle that is the same length on both sides, with the long ends joined. It forms the roof allowing a short overhang on the front and each side of the house. The back should be flush with the back of the house. You can nail/glue this in place.
There should be a way to clean out the house once a year. You can accomplish it by screwing the floor in place for removal or making the roof removable, which is my preferred method. I use small scraps, glued to the roof so that it drops in place and is held by it’s own weight and friction. The clean the house I simply lift the roof off.
Hope this helps, feel free to ask questions. I can probably post/send some pictures tonight if desired.
-- Brad Hancock
View john's profile
john
2370 posts in 4250 days
#7 posted 04-15-2010 06:17 PM
I have a few plans if you want to try one !
-- John in Belgrave (Website) http://www.extremebirdhouse.com , https://www.facebook.com/groups/extremebirdhouses/
View hObOmOnk's profile
hObOmOnk
1381 posts in 3996 days
#8 posted 04-15-2010 06:18 PM
From Amazon.com.
or
you can buy it from Popular Woodworking.
-- 温故知新
View GFYS's profile
GFYS
711 posts in 3340 days
#9 posted 04-15-2010 06:26 PM
different birds need different houses.
backyarder1
#10 posted 04-15-2010 06:48 PM
Thanks everyone. This one works for what I need:
http://store.choosefreedom.com/freeplan.html
